Could hear music from each line-level input on L channel
Large “Volume” knob works perfectly to control L channel
No pops, clicks or anything else, sound is crisp and clear
"Loudness knob" as volume control goes quiet but not to zero, i can still hear it but pretty quiet.
“Protection” did not activate at any time
Thanks! Excellent test results. These confirm the fault is
only on the R channel and is caused by a fault inside
IC401. No need to worry about any capacitors or other parts being the cause of the loud pops and protection mode.
I worked out a simple and reversible way to bypass
IC401. It is done
entirely on the function(2) PC board.
To gain access to the function(2) PC board I recommend
removing the rear panel. Remove
every screw from the rear panel. Note that some may be fine thread screws and others may be coarse thread. I make a diagram as I remove them to remind me where to put them back in during reassembly.
After removing the back panel it should be very easy to unplug the entire function(2) PC board and lift it out of the chassis.
With function(2) PC board on the workbench, locate jumper wires labeled
J406 and
J407. Clip each jumper wire in the middle and bend up the ends.
Next locate 10uF electrolytic capacitors
C461 and
C460. They are near the diagonal connector
W401. Unsolder the
+ wire of each capacitor from the PC board and lift these wires up out of the PC board. Note that the wires to unsolder are the wires
farthest away from connector W401. Note that the
- wire from each capacitor
remains connected as it was to begin with. You will
only be unsoldering the
+ wire of each capacitor.
I use "
solder wick" to remove as much solder as possible before attempting to pull the wire out of the hole in the PC board. I also recommend brushing
rosin flux onto the PC board pads you will be desoldering
before you apply heat. There's plenty of instructions for
desoldering here on eevblog if you haven't done much of this yet. The goal is to unsolder these capacitor wires without damaging the foil pads on the PC board.
Final step is to solder on two new jumper wires. You may use thin insulated wires of the type often used for breadboard circuit construction.
One new jumper wire goes from
upper end of J406 to + end of 10uF capacitor C461Other new jumper goes from
upper end of J407 to + end of 10uF capacitor C460. That's it. Now you will be able to use the "Line 1" inputs (the function selector switch no longer does anything).
The "Pure Direct" switch must stay in "off" mode.
The "Loudness" control is now the volume control.
Note: There is another small (reversible) mod which lets the "Loudness" control reduce volume all the way to zero. This mod requires soldering a couple of jumper wires onto the PC board which holds the "Loudness" control. But this mod is optional if you can tolerate being unable to reduce the volume to zero.
Ultimately,
if you manage to find a working Function(2) PC board this will fix the original problem and restore
complete functionality to the amplifier.
