The big "VOLUME" control works up to number 1 if there were numbers, then nothing until the "LOUDNESS" control up to full volume. i guess I need to check if leaving the main "VOLUME" control on zero still produces sound when turning the "LOUDNESS" control up.
OK let's try this:1) Set main "VOLUME" control (large knob) to minimum (set to "0," which is fully counterclockwise)
2) Then rotate "LOUDNESS" control over its full range. Sound level should get louder as you rotate "LOUDNESS" control clockwise. In fact the normal setting for "LOUDNESS" is
fully clockwise. This is where the "LOUDNESS" bar knob is straight up and down. Rotating "LOUDNESS" knob counterclockwise
should reduce the volume, but I don't expect it to reduce it all the way down to nothing.
3) It is possible that you won't hear any sound at all with main "VOLUME" (large knob) fully counterclockwise, regardless of what position "LOUDNESS" knob is at.
Please tell me whether this is case (or not)?4) If there is no sound with main "VOLUME" fully counterclockwise, then turn it up by 1/4 turn clockwise. Does this get the sound to start coming out?
Also try setting main "VOLUME" control to 1/2 volume, with pointer on large "VOLUME" knob straight up. What does this do?
Does the sound level change any at all when you rotate the large main "VOLUME" knob back and forth between 1/4 and 1/2?
One possibility is that you won't hear anything at all until main "VOLUME" is above 0. Perhaps main "VOLUME" totally shuts off the sound when at 0, but at all settings above 0 the volume doesn't really change. In other words, no difference between 1/4 and 1/2 setting of main "VOLUME" control knob.
5) Repeat steps 1-2-3-4 with "PURE DIRECT" button both
pressed and
released. I don't know which position (button
in or button
out) corresponds to the mode where the BASS TREBLE BALANCE LOUDNESS controls are active and functional.
Details:
- The "PURE DIRECT" switch is supposed to
totally bypass these four controls (BASS TREBLE BALANCE LOUDNESS) in
one of its two positions. In this mode
none of these four controls should do anything at all
- In other position of "PURE DIRECT" button then the BASS TREBLE BALANCE LOUDNESS controls should all "do something" when rotated over their full ranges.
We want to set "PURE DIRECT" button so that BASS TREBLE BALANCE LOUDNESS are all working big "VOLUME" control works up to number 1
Can you explain
"what changes about the sound" at the time when the main "VOLUME control knob is is moved just above or below position "1" ?
Is it like this? When you rotate large main "VOLUME" knob to "above 1" then the sound abruptly cuts out?Does this "1" position correspond to the pointer on large main "VOLUME" knob being near the letter "E" on the word "VOLUME" ?
Both channels of the power section work, the problem is the R output from the pre section.
Understood. For now let's do all testing with the R wire disconnected from CB101. Goal is to get the L channel to be as functional as possible. After that then we will sort out the problem which R channel preamp section still has.
