Hi there,
I'm trying to fix Yamaha A-S501 from the dumpster
, and so far it's been real pain. Here is what I done so far.
Service Manual can be downloaded from here:
https://www.dlmanuals.com/manual/yamaha-a-s301/service-manual The symptom:
The amp is working fine no problem tested for many hours as long as it's not very loud. However as soon as I increase the volume about 1/3 the amp shuts down and the power LED stars blinking. The 1/3 volume position I believe is not relevant to the problem because if I lower the input signal enough I can turn the volume the MAX without triggering the protection but the output sound is very low. The issues also seems to be frequency related because the amp can work for hours but a song with deep base can also trigger the protection.
I use 8 ohms speakers and the Impedance Selector is in position LOW
In self-diagnostic function:
The power LED makes 4 short blinks which is indicating that the DC protection was activated the AD value shows below the normal (48 - 129) usually around 42. (F/W version: V0011)
I checked the output DC voltage sensing circuit on the AMP PCB R177, R178, R179 all good and replaced C133 just in case, then I checked R503, R515, D502 and C532 all looks good but the problem is still present.
Then I disconnected the PRD signal (pin 1 on W505 connector - red wire) from the AMP PCB and ground it through a potentiometer. By adjusting the potentiometer I was able to verify that the DC protection only triggers when the voltage on PRD is outside the normal values (0.947 V to 2.51V). In my case the allowed range is from 0.9V to 2.48V little bit off but I believe still within the tolerance. Based on this I believe there is no problem with the MCU or F/W. With PRD signal disconnected and the potentiometer adjusted so PRD measures 1.5V with reference to ground (MG on the circuit) I put on some music and start to increase the volume this time obviously the DC production didn't trigger and I was able to put some real just to my speakers
. However connecting the PRD back the problem is still present.
Then I focus on the AMP PCB and I measured the DC voltage at the speaker terminals it measured -0.5V on both channels.
Is -0.5V of DC voltage at the output of the amp consider abnormal ?
I tried to measured the biasing voltages of the power transistors of the AMP if they match the voltages on the circuit (the pink numbers), however I have a trouble understanding with reference to which ground should I measured the transistors biasing voltages is it the chassis or the middle tap of the AMP transformer?
Any ideas what could cause this problem ?
Thanks in advance.
