Hi, first post here, so apologies if some ground rules broken.
I have a Yamaha S-701 hi-fi amp that had one power amp blown. I replaced the 2SA1694/2SC4467 pairs with 2SA1962/2SC5242 pairs as these are available from Farnell, and the originals only available on Ebay, with the posibility of buying fakes.
Anyway I got the amp working and testable, can always sort out the transistors later.
BUT, both power amps have 500mV DC on the outputs - turns out this is actually 500mV DC on the speaker grounds.
This trips the amp protection if the output is raised to more than about 10v RMS, load or no load, either side independently, but will power speakers up to that point.
Now, the speaker grounds are also the power amp power supply grounds, but not connected to anything else. They are not connected to chassis.
They only connect to the power amp transformer secondary centre tap, so floating in effect. (There are separate windings for other circuits)
All the input sockets are connected to chassis, and these signal grounds give a ground reference to the power amp at the input stage, though this is not the (floating) speaker output ground.
So the signal ground is only connected to the Speaker ground by components in the input stage of the Power Amp, but the Speaker ground is 500mV higher than signal ground.
The schematic will show this, might make more sense than me.
Connecting a load on the power amp outputs at 500mV draws a current consistant with the DC offset. Connecting the Speaker grounds to chassis passes no current to chassis, the offset goes, and the amps work properly with no protection cutout.
The 240v mains input IEC socket has no ground connection to chassis or anywhere else, the chassis appears to be grounded only by the connected equipment.
This has me confused, I don't really just want to connect the speaker ground to chassis, as this appears to be a deliberate design decision not to do this.
But why the 500mV offset?
