I started the engine and the throttle was going up and down, racing and lugging.
At least that was a sign that the microprocessor was alive.
I looked at the voltage on the big cap.
It was bouncing between 200V and overlimit on my 1000V scale.
Let this be a warning to you.
I was using my Velleman DVM, inexpensive, but not total junk.
I had had it a few years, always reliable.
The old module had arced and burned inside, at least I'm sure/grateful for that.
The new module went in, worked fine.
I went to check the AC voltage output and my meter was going wacky.
With the probes shorted together and one foot from the engine it went bonkers.
I had never seen any meter so sensitive to the ignition EMF.
I checked the insides, the typical aluminum tape with a grounding spring to the PCB.
Years ago, a friend of mine built a circuit that accidentally triggered when someone ran a vacuum cleaner in the room.
I built a replacement circuit and to prove/test it, I demonstrated it operating with a 15 kV neon transformer arcing to the inside of the case.
I guess that I should bite the bullet and buy a Fluke.
