Hello,
I'm trying to repair Yamaha HTR-2067 receiver. It doesn't turn on, no clicks, nothing.
Now looking at standby power supply schematic
There's nothing on
PWR_RY when power button is pressed.
Also I've checked
S9,
ACDET voltages, and both seems to be higher than it's written on schematic.
S9 is about 14V and
ACDET is about 9V.
However, looking further:
There's nowhere else
S9 is connected, just to an 3.3V regulator. Which makes stable 3.3V voltage for microprocessor(I've checked with scope).
Power button is working fine, traced back to the microprocessor. I've also manually connected relay
RY151 from 5V power supply and relay works just fine.
I've also tested output of thermal sensor
IC134 LM19, which output is about 1.75V, so temp is not triggering this.
I'm not sure where to look now... One important thing - main power supply caps looks wierd to me, their vents are kinda bloated. Gonna take them out and check ESR.
Full service manual -
https://ufile.io/saae8Edit:
Problem was that microcontroller detected low ac voltage multiple times.
I've managed to get into diagnostic menu, which resets the mcu and now receiver works just fine.
It seems like on these Yamaha's when protection system is activated 3 times in a row, it won't power on anymore, unless in diagnostic mode.
