Author Topic: Yamaha HTR 3063 (RX-V367) no sound or video  (Read 3535 times)
Offline abhi1981Topic starter
  • Country: in
« on: July 30, 2021, 11:22:27 am »
Hello,
I have a Yamaha HTR 3063 (RX-V367), which has now been dead for several years.
It worked fine for the first 2 - 3 years, then first the HDMI video went out and then later the HDMI sound also. Not even analog sound works. All this happened just after warranty   >:( >:(
The front display is good, all the controls work, the relays click, volume control works, but that's all.
The service center is charging almost 50% of its price in repair. They will change the HDMI board.
I don't know whether the board is actually bad or they are just trying to make money. How can I test the board?
I tried resetting it, but that didn't help :-//
If the board is beyond repair, can it be used as a stereo amp, by bypassing the digital circuit somehow. Please advise.
I have the service manual, but it's too big to attach.
1240466-0
1240468-1
Offline ambrosia heart
  • Country: hk
Re: Yamaha HTR 3063 (RX-V367) no sound or video
« Reply #1 on: July 30, 2021, 12:23:20 pm »
Not even analog sound works. All this happened just after warranty : seems to be DSP problem. :palm:
This gives me a clue: charging almost 50% of its price in repair. They will change the HDMI board (Japan brands
company policy)  :(
Download service manual (your model)
See p.30 and  then see 44 to confirm if DSP goes wrong. :)
The following users thanked this post: abhi1981
  • Country: in
« Reply #2 on: July 30, 2021, 02:38:35 pm »
You are right :-+, its a DSP problem. What to do next?
« Last Edit: July 30, 2021, 02:42:26 pm by abhi1981 »
  • Country: hk
« Reply #3 on: July 31, 2021, 03:11:49 am »
See pm and photos
  • Country: in
« Reply #4 on: July 31, 2021, 07:26:41 am »
Thank you very much ambrosia.
This is the first time in years that I received a solution to my problem.
Now, atleast I know it's the DSP chip.
Thanks again for explaining everything so well. :-+ :-+ :-+ :-+
I will get back to you with further developments.
« Last Edit: July 31, 2021, 07:28:29 am by abhi1981 »
  • Country: in
« Reply #5 on: July 31, 2021, 07:34:18 pm »
Just checked all the DSP pins for continuity with motherboard, and they all seem good. I put one lead of multimeter on the chip leg and another on the nearest connection. Is this method OK??
Checked the voltages of pins 1 to 36 (a job requiring great patience  :phew: :phew:
Will check the remaining pins tomorrow.
PIN#   Voltage
1   0
2   1.49
3   3.15
4   0
5   0
6   0
7   0
8   1.14
9   0
10   3.17
11   0
12   0
13   0
14   3.17
15   0
16   1.14
17   1.48
18   0
19   3.13
20   1.14
21   0
22   0
23   0
24   1.14
25   1.14
26   0
27   3.17
28   3.13
29   3.13
30   0
31   3.17
32   3.16
33   1.14
34   3.16
35   3.13
36   0
  • Country: in
« Reply #6 on: August 01, 2021, 03:55:31 pm »
Pin 37 to 72. Lots of fluctuation :-//
37   2.69-3.17
38   3.17
39   3.17
40   0
41   0.96
42   3.17
43   0.82
44   1.14
45   0.8-0
46   1.0-0
47   0
48   0.88-0
49   1.0-0
50   3.17
51   3.17-0
52   0
53   1.14
54   0
55   1.45-0
56   3.17-0
57   1.15
58   0
59   0-0.5
60   3.17
61   0-0.3
62   0
63   0-0.9
64   3.17-0
65   1.14
66   0
67   3.17
68   3.17
69   0
70   1.6-1.59
71   3.17
72   0
  • Country: hk
« Reply #7 on: August 02, 2021, 03:50:53 am »
37   2.69-3.17
38   3.17
39   3.17
40   0
41   0.96
42   3.17
43   0.82
44   1.14
45   0.8-0
46   1.0-0
47   0
48   0.88-0
49   1.0-0
50   3.17
51   3.17-0
52   0
53   1.14
54   0
55   1.45-0
56   3.17-0
57   1.15
58   0
59   0-0.5
60   3.17
61   0-0.3
62   0
63   0-0.9
64   3.17-0
65   1.14
66   0
67   3.17
68   3.17
69   0
70   1.6-1.59
71   3.17
72   0
Measuring ALL values of a dsp chip are not important in your case. :)
When you troubleshoot a hdmi board, all voltages MUST
measure by an oscilloscope. This is a guideline from
service dept. Why see pm. :-BROKE
What you need is an oscilloscope to measure if the signal
generated from the main CPU is ok. This signal tells the
DSP to work properly. See you tube I sent to you via pm before.
You must make sure this signal is present & ok (comparing you
tube film); otherwise even you replace the DSP chip, it will
not work properly.  This explains why HDMI board is the hardest
part in troubleshooting an AV-amp. Remember measure voltages by
an oscilloscope. JUST to measure ALL VDD points is enough.  :-BROKE
Bad soldering joints in HDMI board hardly found, trust me.
Tell you a story when I troubleshooted
a HDMI board of onkyo in 2014.  This story
told you this signal was so important.
See pm.
How to measure the signal. See pm
No need to measure all voltages of a dsp chip
just measure the voltages supplied to dsp chip VDDs
Basically ALL VDDs connected to a small capacitors,
why connected to a small cap see pm.
I do not have time to help you to check voltages ALL, just DIY.
comparing with the marked ones on service manual, just 3.3V
Ask your friends,old classmates, colleagues,neighborhood
or university profs. (if you studied science) to borrow
an oscilloscope of about (10-20MHz) to measure that signal.
Once this signal is ok, you can fix this amp.
If everyone in your country HATES you, :palm: sorry, you are
unable to borrow an oscilloscope. :palm: LOL. Call friends to
help you!!! ;)
No oscilloscope, no talk. ;)
  • Country: in
« Reply #8 on: August 02, 2021, 04:28:54 am »
Oscilloscope very very expensive in India. Very few people have it, And they HATE me ;)
Can the receiver be used as an analog stereo amplifier, by conecting to the amp board directly?
« Last Edit: August 02, 2021, 05:54:42 am by abhi1981 »
  • Country: hk
« Reply #9 on: August 02, 2021, 06:11:57 am »
OK. :)
Borrow this. I will tell you how to measure tomorrow. :popcorn:
  • Country: in
« Reply #10 on: August 02, 2021, 08:32:34 am »
I have this  ;D ;D
  • Country: hk
« Reply #11 on: August 03, 2021, 02:45:52 am »
Normally, end users reset their amp by pressing buttons. Now I am telling
you how to reset your amp by a wire. Steps see pm video and photo.
Do this experiment to reset your amp first, then dsp. 8)
Structure of amp reset and dsp reset are same. (photo upload later) ;)
Borrow an analog mutimeter with 0.5V measurement is a must. :)
  • Country: in
« Reply #12 on: August 03, 2021, 01:09:27 pm »
Oh dear !!!! I threw away my analog meter about 15 yrs back  |O |O :palm: :palm: (it was broken anyway)
I'll try to arrange one.
Thanks for all the help ambrosia :-+ :-+ :-+ :-+
  • Country: hk
« Reply #13 on: August 04, 2021, 02:31:15 am »
Just wait, I will give you a full picture
tomorrow.  Don‘t do the steps today.
A more detailed steps will send to
you through pm.  Be patient. :)
  • Country: hk
« Reply #14 on: August 05, 2021, 06:51:51 am »
Remember to cover ALL 220V input buy a cardboard such as
the large power transformer (see photo) and the standby
board to prevent accidentally touching of the live wire.
This is lastest version  see pm. :)
print it out and read it  carefully. :D
Be patient!!! when doing these 23 steps. ;)
Be careful during voltage measurement. Don't short the pins.
such as red probe making pin 1 and 2 touch each other .
I recommend using a needle see photo.
Preliminary test is very important. Why? Watch a video on you tube
 I sent to you via pm. This is a reset problem of a pioneer av-
amp vsx, unfixable. This amp remains in my home. The
waveform, oh dear, fucking weird , never goes to zero.
It should go back to zero line!! (compare that one with
the yamaha reset I sent you before)
When ALL (reset and voltages of dsp chip vcc) are ok, replace the dsp chip.
Don't forget to find a tech with a good word of mouth o f desoldering
and soldering techniques. Tech. needs to remove 144pins dsp chip and
resolder it back to HDMI board. Watch him and learn some skill (pay
lesson fee for the technique of desoldering  and resoldering 144 pins dsp chip)
Important thing speak 3 times:
Don't DIY. Don't DIY. Don't DIY
Let a talented tech. earn such money.
-End-
  • Country: in
« Reply #15 on: August 05, 2021, 08:13:57 am »
Dear Ambrosia, you are a genius. :-+ :-+ :-+ :-+. You have very good knowledge. You have explained everything so well.
The so called 'techs' here in India, don't understand the difference between voltage and current, leave alone digital electronics. At the most they can repair old analog circuits by hit and trial  :horse:.
Aroung 15 yrs back, people used to repair computer motherboards (when motherboards were expensive), but ever since they became cheap, no one repairs them now.
The DSP chip or any other chip is not available anywhere. Aliexpress was one option, but that too is banned in India after the pandemic :palm: :palm:
I might get a used board which will cost me atleast $70. I had purchased the receiver new for $200 (at 50% discount  ;)). I can even get a used amplifier for $100. So, it is not economical to get it repaired from anyone.
Because of these reasons, it will have to be a DIY job.
I might learn to do it myself  ;), since I have nothing to lose.
  • Country: in
« Reply #16 on: August 05, 2021, 04:50:35 pm »
Just ordered an analog meter today. I'll get it on saturday.
How are these cheap $20 oscilloscopes??
  • Country: in
« Reply #17 on: August 14, 2021, 04:36:19 pm »
Can we feed analog audio signal directly to IC21???  :-// Maybe this way it can be used as a power amplifier. I can connect it to my Denon amp. Please advise.
« Last Edit: August 14, 2021, 04:41:45 pm by abhi1981 »
  • Country: hk
« Reply #18 on: August 15, 2021, 03:03:58 am »
Can we feed analog audio signal directly to IC21???  :-// Maybe this way it can be used as a power amplifier. I can connect it to my Defnon amp. Please advise.
(Attachment Link)
Turn on the amp. :)
Take Photo front panel, I will tell you.  See photo
My favorite  scene, salute! :-+
  • Country: in
« Reply #19 on: August 15, 2021, 05:09:18 am »
  • Country: hk
« Reply #20 on: August 15, 2021, 06:15:09 am »
Brother, amp must be switched on , like thread #3. :popcorn:
Front panel must lit up. See photos
No Diag mode.
« Last Edit: August 15, 2021, 06:25:11 am by ambrosia heart »
  • Country: in
« Reply #21 on: August 15, 2021, 07:55:04 am »
  • Country: hk
« Reply #22 on: August 15, 2021, 08:40:29 am »
(Attachment Link)
If you really want to do this step.  Ok, I will tell you
the steps  tomorrow.
You will suffer the consequence :palm:--- burn all speakers when volume is too high or a large dc output caused by voltage amp faulty or power amp transistors shorted, however.
If I were you, I would sell it out. It is up to you.
I have already told you the risk and consequence.   :)
See pm
« Last Edit: August 15, 2021, 08:50:09 am by ambrosia heart »
  • Country: in
« Reply #23 on: August 15, 2021, 11:22:49 am »
OH DEAR more consequences  :palm: :palm: :palm: :palm: |O |O |O |O |O
No one will buy a dead amp. It can be used only for spares.
« Last Edit: August 15, 2021, 11:27:32 am by abhi1981 »
  • Country: hk
« Reply #24 on: August 16, 2021, 02:48:35 am »
Steps to do see pm. :)
The risks and consquences I mentioned before can be solved by a little bit of money $$.  :-+ :)
Reason see pm also.
If you want, I will pay for you and buy it for you from taobao at cheap price  :-+
comparing aliexpress. :-- What I need is your address. 8) Or you can buy it from here
https://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20210815183313&origin=y&SearchText=speaker+delay+board
I recommend this one from taobao
https://item.taobao.com/item.htm?spm=a1z0k.7385961.1997985097.d4918997.2de029d3CUG1qW&id=617451080348&_u=t2dmg8j26111
This board protects precious spks from damages by using upc1237  :) with regulated and stabilized dc supplied from LM7812. :-+
Relay so beautiful Omron GOOD brand :-+. Look at the board. It has a power led to tell you the board is now working for you. ;)
Fabulous and Gorgeous!!! :popcorn:
How much is this fucking thing? 26HKD for kit and soldered 28.5HKD  :wtf: SO cheap. They are Fabulous and Gorgeous!!! 10HKD shipped to destined station
for you to pick up in HK. 8) :-+ This fucking thing helps you to prevent precious spk from getting damaged. :box: If I were you, I would buy it. :) :popcorn: :-+
