Hey all!
I am looking for some guidance in repairing a Yamaha HTR-5760 receiver that I took out of storage. I am a relative newb but I do have some experience replacing boards and soldering, and I do have a multimeter and the service manual. However, the electronic diagrams are gibberish to me and I am unsure where to start. I am hoping there is a blown capacitor or something similarly easy I can replace.
Anyways, here is what is happening:
The unit turns on for a second then turns off. There is a small click when it turns on and off coming from the board behind the power supply, but I believe I remember those clicks as normal. It turns off with speakers connected or not.
I am able to access DIAG mode, but only in protection cancel mode. In DIAG, there are a few findings with potentially various levels of significance. When I switch into menu number 8: VFD Check, there is a louder click coming from a Omron G5PA-28 power relay(?) at the back on the unit. It clicks again when I move out of menu 8. As well, in menu number 9: TEST ALL, when I scroll through the individual tests, the relay clicks when I reach TEST PRES L or R, but not when scrolling between the two of them. I have no idea if this is normal behaviour.
The last noteworthy finding is on menu item 11: AD DATA. The DC is listed at 7, well within the parameters of 1-13. However, the PS constantly switches between 21 and 22, 21 being out of the parameters of 22-47. This, along with the error on entering the DIAG mode of PS PRT : 022 E, seem to point to a potential problem with the power supply or something which triggers the protection function.
So, I am wonder what my next steps might be and/or recommendations to further understand the issue. I can take some voltmeter readings but I am unsure were to take them and what I should be looking for. Any assistance would be appreciate!
Thanks!
Helblind
