Thanks,
I'm not using a powered subwoofer, the s/w speaker is connected to the o/p jacks on the rear of the unit. I haven't tested the cable yet as I only discovered the fault late yesterday. I plan to swap the s/w o/p with one of the surround o/p to see if it definitely the s/w channel after I test the cables.
In my early days as a tech (I am now retired) I was taught not to leave speakers disconnected as that would blow the o/p chips, hence my thinking that as the leads had become disconnected, the o/p stage might have blown. Modern gear might be more robust though.
Regards
Steve
