Hi there,
i recently purchased a non functional Yamaha RX-V450. After all it's just the C405 that needs to be replaced
But i didn't have the right replacement cap. So i ordered a few. In the meantime i thought i would look around what other cap i had around.
So after a bit of looking around i found a similiar cap. Same type, same voltage rating of 600V but 100nF instaed of 22nF. LCR meter said it had around ~70nF.
Close enough i thought. So i put it in and the amp worked perfectly.
Until today (a day later). The Yamaha doesn't turn on anymore. I opened it up again to put in the proper 22nF cap that arrived today as well.
But when i took a closer look at the board i found out that the power supply kind of exploded :\
R412 (2.2kohm resistor) is pretty much blown away and some traces on the back are blown off as well.
I fixed the traces, replaced the resistor, the cap and the mosfet Q404 for good measure. But it's still dead. The fuses are fine. But it doesn't draw any power.
I'm not done trouble shooting yet but i just wanted to ask: what the hell happened there? ^^
edit:
Btw. this is the service manual:
http://www.audio-circuit.dk/downloads/schematics_v-z/Yamaha-RXV550-V450-HTR-5750-5740-DSP-AX450-av-sm.pdfThe affected board is on page 49/82. The traces are damaged from the source of Q404 over D405 up to R412. D405 and R412 were destroyed and i have replaced them.
The amp now draws 5W when plugged in but refuses to turn on.
Maybe because my zener diode has the wrong value. I only have some BZX55C5.1 around. The right one would be a MTZJ10B. I have also replaced Q404 (K3491) with a 2N60LB. The 2N60LB is apparently not quite as high speed as the original K3491.
Still not sure what happened though. Was C405 not completely discharged due to the higher capacity and charged up to a high voltage? Like in a flash charging circuit? I'm confused.
