Author Topic: Yamaha RX-V483 PS2 fault  (Read 8493 times)
Offline nsbenzTopic starter
« on: November 19, 2018, 03:09:12 pm »
I have a receiver that went into protection mode.  When I start the receiver in diagnostic mode I see the error PS2 PRT: 0089 show on the display.  I can not find any service manuals on this.  Any idea what to check?
Thanks,
Neil
Offline PKTKS
  • Country: br
Re: Yamaha RX-V483 PS2 fault
« Reply #1 on: November 19, 2018, 03:24:05 pm »
Very cryptic - you do need the proper manual or close that to decipher
In general terms  PRV PRD are POWER error codes
all other codes will tell you where the fault is.
Like this other one..
and THEY ALL DIFFER so you need some proper error table
bad consistency from Yamaha on this issue
Paul
« Reply #2 on: November 19, 2018, 03:27:35 pm »
That's the problem I am having I can not find any service manuals on this unit.
Thanks.
Offline mzacharias
« Reply #3 on: November 20, 2018, 01:24:01 pm »
Hi-Fi Engine has the manual. You have to register but it's free.
https://www.hifiengine.com/
« Reply #4 on: November 20, 2018, 08:00:40 pm »
Looked at the service manual, any ideas where to start?
Thanks,
Neil
Offline PKTKS
  • Country: br
« Reply #5 on: November 21, 2018, 12:38:57 pm »
we need the manual too dude.
Offline ElecSeb
« Reply #6 on: November 21, 2018, 01:08:50 pm »
Your code means:
PS2 PRT: 089 (I suspect you typed 1 zero to much)
  • PS2 = When the protection function worked due to abnormal voltage in the power supply section. [PS1, PS2, PS3] -> your case PS2!!
  • PRT = Protect!!
  • 0089 = A/D conversion value of voltage at the moment when the protection function worked (Reference voltage: 3.3 V=255)
Please share your manual, I checked mine and copied the above!
Additional:
Cause: The voltage in the power supply section is
abnormal.
Supplementary information: The protection function
worked due to a defect or overload in the power supply.
Turning on the power without correcting the abnormality
will cause the protection function to work in 1 seconds
and the power supply will be shut off.
I just copied all this from the manual of your receiver (5min work) -> now we need your photo's and schematics what you checked and what is found.
PS1/PS2/PS3
Power supply voltage (PS) protection detection.
The voltage at 96 pin (PS1_PRT)/97 pin (PS2_
PRT)/98 pin (PS3_PRT) of IC22 are displayed.
Voltage detects
PS1: AC_BL, AC_12, ±7A, +3.3S
PS2: ±12A, +5A, +5VID, +3.3T, +41F
PS3: +5.5V
Normal value
PS1: 29 to 118
PS2: 135 to 191
PS3: 132 to 168
* If PS1, PS2 or PS3 becomes out of the
normal value range, the protection function
works to turn off the power.
« Last Edit: November 21, 2018, 01:24:27 pm by ElecSeb »
Offline mzacharias
« Reply #7 on: November 21, 2018, 01:59:21 pm »
Check every power supply line you can find. +12, +5, -5, whatever. My guess you'll find one voltage low or missing.
Offline ElecSeb
« Reply #8 on: November 21, 2018, 02:27:03 pm »
My 2 cents check (probably they are broken -> they measure nothing and should measure):
R5225 - 12K (in -12V line)
R5224 - 12K (in +12V line)
R5223 - 1.2K (in GND/common if I switfly looked)
If this is OK, then measure the output here:
IC523 = 12V
IC524 = -12V
« Reply #9 on: November 21, 2018, 06:33:13 pm »
Here is the manual, I will try and test the voltage.
https://drive.google.com/file/d/1gHSoUo6viJfiLVlNTF1FAIbUTT7tmW4c/view?usp=sharing
Thanks
Offline PKTKS
  • Country: br
« Reply #10 on: November 22, 2018, 12:24:56 pm »
I've done a really fast guess based on the error code only
which sometimes may be triggered by other issues...
I would start right there on the PS2 output section
this  place would be a good start point
 thanks for the manual.. it helps
Paul
« Last Edit: November 22, 2018, 12:27:31 pm by PKTKS »
Offline mzacharias
« Reply #11 on: November 24, 2018, 01:39:37 pm »
By the way, refer to the service manual regarding the Protection Cancel start-up option.
Incredibly useful for troubleshooting.
