Author Topic: Yamaha RX-V485 turns off automatically after 3 secs  (Read 2943 times)
Offline qamarahsanTopic starter
« on: April 24, 2020, 10:54:05 am »
Hi Folks, I am looking to troubleshoot my Yamaha RX-V485 which is showing the error DC PRT 000 when put in diagnostic mode. I can't seem to figure out what is causing this.
Can someone help me find out the service manual so that I can start troubleshooting.
Offline PKTKS
  • Country: br
Re: Yamaha RX-V485 turns off automatically after 3 secs
« Reply #1 on: April 24, 2020, 11:07:01 am »
https://www.hifiengine.com/manual_library/yamaha/rx-v485.shtml
Try the 483 service manual
Yamaha is pretty much consistent although
not simple to deal with
Paul
« Reply #2 on: April 24, 2020, 11:10:19 am »
Been trying to register on this site but gives me an error. If you are registered, can you download it for me and send me a link where I can retrieve it?
Offline PKTKS
  • Country: br
« Reply #3 on: April 24, 2020, 11:36:15 am »
Usually it does not...
File is way too big for attachment here.
Not even in parts.  Limits are too low
Try again  - if it fails drop me a note here
Paul
Offline mzacharias
« Reply #4 on: April 24, 2020, 01:25:39 pm »
The service manual has a "protection cancel" mode to allow troubleshooting.
This is good for all protection modes except high-current, such as a blown channel, shorted filter cap etc.
Engage this mode, then I would suggest checking the output of all voltage regulator IC's.
DO NOT connect speakers at this time as there is a high likelihood of DC offset from the speaker terminals.
There is also a small chance of a bad electrolytic capacitor in the regulated power supply area, either open circuit or shorted - either condition will trigger the protect.
Offline kawal
« Reply #5 on: April 27, 2020, 03:01:37 am »
I repaired a few Yamaha recievers and  a lot have issues with power transistors. Must be a design flaw. The older V series did not fail on the output stage but failed regulators on regular basis. Putting the receiver in test mode helps pinpoint the issue.
« Last Edit: April 27, 2020, 12:51:51 pm by kawal »
« Reply #6 on: May 02, 2020, 12:10:33 pm »
So I got me a multimeter and tested the voltages on each of the speaker outputs. All were the same value except the Surr L which was giving a 48V as opposed to 13mV in the rest of the outputs. At least its a start. I still am however not able to get my hands on the service manual. Paul, can you please help sending me the one you have. I have never tried this before, but will give it a shot since the place I am currently in, I will not be able to find any warranty on the box.
Offline kawal
« Reply #7 on: May 03, 2020, 03:47:40 pm »
Well that is easy now  . Power stage is broken. Very common thing I find in these.  Take out transistors and figure out which one is broken and replace. Most likely the big power transistor on positive rail.
This is not the exact manual but should be close
https://elektrotanya.com/yamaha_htr-5140_rds_rx-v495_rds.pdf/download.html
https://elektrotanya.com/yamaha_rx-v481_htr-4069_rx-v481d_sm.pdf/download.html
The power stages are pretty generic and should look like the one attached.
« Last Edit: May 03, 2020, 04:13:23 pm by kawal »
The following users thanked this post: qamarahsan
Offline kawal
« Reply #8 on: May 03, 2020, 04:25:14 pm »
BTW the amps that have 2SC5198/2SA1941 dont seem to fail as much as the weeker 2SA1694/2SC3856 pairs.
