Author Topic: Yamaha RX-V659 Power problem  (Read 4706 times)
Offline ysonmezerTopic starter
  • Country: tr
« on: May 27, 2017, 08:04:05 pm »
I use a Yamaha RX-V659 receiver. I had previously burned the capacitor on the power board 22nf 630v. I changed it with 22nf 1000v so that it would burn again. The device recently made a power failure. This condenser series had a 220k resistor burned. I changed but the device did not work. These two components are attached to the series burnt surface mount 10v zener. I changed and worked.
Offline mzacharias
Re: Yamaha RX-V659 Power problem
« Reply #1 on: May 29, 2017, 11:58:43 am »
R661 should be 2.2K (2200 ohms) not 220K.
Offline oldway
« Reply #2 on: May 29, 2017, 04:22:39 pm »
And C654 must be a X2 capacitor for safety.
With C654 = 22nf 275Vac X2, you should never burn R661, nor the zener diode.
« Last Edit: May 29, 2017, 04:27:38 pm by oldway »
