Good morning/afternoon all!
Firstly, I am a newbie to electronics so please forgive me! However 2 weeks ago we had some issues (potential neutral fault) in our building (comprising of 26 apartments) that led to a number of electronic devices failing to power on. So far, I have managed to repair our 2 Sonos speakers which were relatively easy to diagnose and repair (blown capacitors and radial fuses).
Next up is our Yamaha RX-V673, I was hoping to have a go at repairing it myself before resorting to either paying someone else to have a look. Upon visual inspection on the Video-2 PCB when power comes in to the system, I noticed that F3701 (T2.0A Anti-surge Slow blow radial fuse) had blown, as well as capacitor C3706 (KXJ 400V 68uF) which had a bulge in the side and lid. I replaced both of these and reapplied power, unfortunately however the fuse at F3701 keeps blowing each time in quite spectacular fashion (loud pop, smoke and flash).
In the photos of the solder side, I had removed the safety capacitor at C3704 to test, however from my reading it appears X2 capacitors rarely fail. From what I can tell, it should not be too complicated to identify the issue as there is only a limited number of components that could be at fault - considering it appears to be an issue with actually getting power into the system.
Unfortunately I am limited in terms of electronics knowledge and equipment (other than a cheap soldering iron and basic multimeter).
Any pointers would be greatly appreciated!
Many thanks,
Adam
