Author Topic: Educator II Power Supply schematic?  (Read 193 times)
Offline AxtmanTopic starter
« on: August 15, 2024, 10:37:32 pm »
Does anyone have a Hep Kit by Motorolla Educator II Power Supply schematic? This unit is plus/minus 5 volts for, I believe, a breadboard digital learning unit.
Offline MathWizard
Re: Educator II Power Supply schematic?
« Reply #1 on: August 17, 2024, 08:03:00 pm »
So it's a demonstration microcomputer from 1976 ? Whatever was in the PSU, there's probably not much to it. It might just be a center tapped transformer, rectifiers, filter caps, and 7805/7905 regulators. Or it could use a few discrete BJT's to make  regulator circuits.
Do you own one and have a problem? Did you open it up ? Just from a top/bottom PCB picture, or with a DMM, it would be pretty easy to map a PSU like above.
