Author Topic: Yamaha RXV-2600 capacitor issue - bulky fix  (Read 3471 times)
Offline HendriXMLTopic starter
    • KiCad-BOM-reporter
« on: September 20, 2020, 08:45:01 pm »
5 years ago I repaired my Yamaha receiver with the famous C4 22 nF capacitor replacement. Comparable to this:
https://youtu.be/MwvjAtSr5t8
However the first signs are showing it's faulty again. Some person on the net mentions it should be replaced by a X2 rated dielectric capacitor.
I went searching for those on some old pcb-s and found some. But most off them are a fraction of their spec.
This raises the question what is better a new one that will drop, or an old one that has already dropped, but has reached now 30 nF. (A bit too high?)
Maybe there's some type of capacitor doesn't need replacing that often?
« Last Edit: September 24, 2020, 07:18:18 pm by HendriXML »
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
Offline aqibi2000
Re: Yamaha RXV-2600 capacitor issue
« Reply #1 on: September 21, 2020, 07:34:26 am »
5 years is a good life
Out of the usual 20% spec
Tinkerer’
Offline andy2000
« Reply #2 on: September 21, 2020, 02:00:24 pm »
I generally consider film caps like that to be lifetime caps.  They rarely fail unless abused.  Clearly that cap isn't right for the application.  I would probably try a higher voltage part.
Offline mzacharias
« Reply #3 on: September 21, 2020, 04:56:58 pm »
The RX-V2600 is nothing like the receiver shown in the YouTube video;
That cap is not present, and is not the problem.
You did not even mention the problem you are having with the 2600; however I will mention they did have a problem with the electrolytic capacitors in the low-pass filter portion
of the feedback loop on these. 47uF or 100uF (I forget which) associated with the differential pair for each amp circuit. The DC offset may wander around or go full high,
triggering the protection circuit.
« Reply #4 on: September 21, 2020, 05:26:18 pm »
Hi Mzacharias,
From browsing the forum before posting this one, I saw you're knowledgable about repairing Yamaha's. I didn't mention the symptoms because the problem was already diagnosed. I had the same problem 5 years ago. And fixed it using the links posted below. Later I became more interested in electronics and saw Dave's video with a similar problem.
Maybe you can advise a cap which result in a more durable fix? It is an easy fix but it takes quite some time to get access to the receiver.
https://www.diyaudio.com/forums/solid-state/226279-yamaha-rx-v2600-power.html
https://www.avforums.com/threads/yamaha-rxv1700-power-problem.1533016/
« Last Edit: September 21, 2020, 05:36:15 pm by HendriXML »
« Reply #5 on: September 21, 2020, 05:48:55 pm »
In the service manual C4 is mentioned multiple times in the part list, does this mean it can be replaced with the best pick of those?
« Reply #6 on: September 21, 2020, 05:52:19 pm »
Looking at the list in my previous post, this might also be what the service manual suggest. Replacing it with a 630V one, and also higher capacitance.
I guess it has to be a safety capacitor?
I took an image of the best match I could find on some PCB. It's capacity has dropped to 30 nF. It voltage is on the low side, but I guess OK.
« Last Edit: September 21, 2020, 06:02:10 pm by HendriXML »
« Reply #7 on: September 22, 2020, 12:20:54 am »
There's an extra column not shown which shows for which country which capacitor spec is ment, so mine can only be replaced by a 22 nF. Quite logical because it kind of drops mains voltage.
So I won't be using the desoldered one.
« Reply #8 on: September 24, 2020, 07:03:48 pm »
Because it would be the second repair of the same problem I wanted a better fix. As mentioned in this thread one with a higher voltage rating might be better. I decided to go with 1,5/2,5 kV from a crt tv. The ones it had where 8,2 nF. Having both in parallel means it gets to 16.4 nF. But because the faulty one was only 7 nF, and probably was just over the edge of resulting in failing I think they're good enough. I measured quite a few film capacitors and a lot of them where only a fraction of their intended spec. Hence the idea of taking high quality ones which were stil spot on, even after being in use.
They're a bit heavy so I drilled 2 holes for some tie wrap. Space enough  :-+.
After this fix the receiver works as expected. The idea is now that those over dimensioned ones won't drop in capacitance.
« Last Edit: September 24, 2020, 07:08:18 pm by HendriXML »
