Author Topic: Yamaha rxv-657 goes to protect. Help!  (Read 919 times)
Offline strat1953Topic starter
« on: December 24, 2020, 11:57:59 pm »
its turn on then goes right to protect.i changed c405 but did not fix it. i also checked all the amp section transistors and the amps fine.if theres a yamaha tech that knows what or where the problem is or where to look,i will gladly paypal you  to repair advice. you can also text me 480-703-9586 or email strat1953@aol.com thank you. i also have a 757 with the same problem
Offline mzacharias
Re: Yamaha rxv-657 goes to protect. Help!
« Reply #1 on: December 26, 2020, 04:12:24 pm »
Do you have the service manual and know how to use a multimeter?
Most shut-downs on Yamaha's relate to regulated power supply issues (bad voltage regulator like a 7805, 7812, 7912, etc) or a DC offset on a single channel.
Blown amplifier channels cause a much faster shut-down, so fast the display never lights up, and you only hear a quick single click.
