Let’s focus on TR9 (2SA881). This transistor regulates the 8V rail.If there is an excessive load on the 8V rail then TR9 will become quite warm or too hot to touch soon after applying power. According to the user manual the total power consumption of the SY22 is <8W, which corresponds to drawing <600mA total from the 12V power supply. It is safe to assume that most of this power is used by the 5V rail which powers all of the logic chips. I estimate the total current flowing through TR9 should be <100mA. With a 4V drop from C-E this gives TR9 a power dissipation of ~400mW. This will make Tr9 "warm," but not "too hot to touch."
The circuit around TR9 is simple. TR9 acts as an “emitter follower.” Its base voltage is supplied by 9V zener ZD1. The emitter will be 0.6V lower than base, ~8.4V.
To diagnose this circuit:First measure and post these 3 voltages at TR9, measured with - probe connected to circuit ground:
C (Should be 12V or same voltage as external power supply)
B (Should be 9V)
E (Should be between 8V and 8.5V)
Next, with external power supply disconnected, measure the in-circuit resistance of the 2 resistors connected to cathode of zener diode ZD1. One resistor should be 270 ohms, the other resistor 100 ohms.
To test TR9 in-circuit with multimeter having “diode-check” feature:
First disconnect external 12V power supply
E-B should measure about 0.5V with positive test probe on B
C-B should also measure ~0.5V with positive test probe on B
E-C should not measure 0.0V (but you might get a reading which isn’t “open circuit”)
If you have the capability to unsolder and remove TR9 from the PC board then some additional tests can be done.
First take a photo or make a drawing to help remember the correct orientation for reinstalling TR9.
Please post photos of TR9 on the PC board prior to removing it.To desolder without damaging PC board I recommend brushing a small amount rosin flux on the 3 PC board pads for TR9. Also dip your desoldering wick in the rosin flux (a tip I learned only recently - even though desoldering braid already contains some flux, it helps greatly to add more flux). Put the desoldering wick against the pad and heat with soldering iron until all the solder flows into the desoldering wick. Remove all of the solder so that TR9 can be moved easily. The goal is to be able to gently pull TR9 out without damaging the PC board.With TR9 removed it can again be tested with multimeter “diode-check.” It can also be tested with one of these “$20 transistor tester” devices:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/Before reinstalling TR9 I recommend applying power and measuring the voltage across zener diode ZD1. This should measure about 9V. Then check voltage from circuit ground to the B pad for TR9. The measured voltage should be exactly the same as the voltage you previously measured across ZD1 (9V).
