Author Topic: Yaskawa CIMR-04AS3 Inverter for CNC  (Read 278 times)
Offline SpikeeTopic starter
« on: January 16, 2024, 11:29:30 pm »
Hi all,
I recently bought a used CNC machine for the hobby which came with a known fault being an issue with the ATC.
So far i have figured out that the issue lies in the inverter (it goes into fault mode number 5). Unfortunately, there are no schematics available for this Junspeed S300 inverter.
When I inspected the PCB i saw that two traces were missing and that resistor R2 was broken. I fixed this (also renewed the big capacitors) but when plugging it in again R2 resistor burned out immediately.
Note traces have been repaired at the red circle. ; the control board mounts on this
Control board:
I have deducted the schematic to be this:
Note some connections not filled in due to being hidden; most of them going to the big connector LW1.
Datasheets I found:
RY1 - relay - https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/2601/JR%20Relays.pdf
TR1 - BJT NPN - https://pdf-html.ic37.com/pdf_file_B/20200531/pdf_pdf/PdfOld/icpdf_datasheet_9/ET391_datasheet_93455/152354/ET391_datasheet.pdf
Unfortunately I was unable to find the datasheet of PM Mitsubishi Electric QM10KD1-HB
Measurements:
R-S: 17Kohm
R-T: 9Mohm
S-T: 9Mohm
U-V: 25Kohm
U-W: 187ohm
V-W: 25Kohm
Any tips&tricks regarding how to diagnose this? I'm not very well versed in power electronics so I'm a bit out of my depth here.
I'm hoping I can get this going again. Any help is appriciated~
« Last Edit: January 16, 2024, 11:48:59 pm by Spikee »
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
