Hi guys/gals,
Before I dig deep into the service manual, I would like to get some advice on this failure.
For starters, it fails all the ohm source related self tests like 612, 613, 615 & 617.
With no input, and set to 2W mode, the ohm reading just seems to float. With any sort of resistance connected, the meter will read .22 ohms. It does not matter whether I have the input shorted or measuring a 1K or 10K resistor, the meter reads .22 ohms.
DC volts seems to work properly.
I've read some of the threads here and already checked a few things.
I get no voltage at the input jacks of the meter when measuring with another meter in any ohm range. I have also checked all the main voltages including ripple and everything seems to be ok. This includes the 7 & 10 volt references. There is also a 5 volt drop across CR203.
The same result applies to the rear inputs. 4W gets pretty much the same result except instead of reading .22 ohms it reads a dead short, .000 ohms.
Since this is my first 34401A, I am wondering if it's normal to hear 2 beeps when the unit is first turned on.
Any help would be appreciated.
Thanks in advance!
