I saw the C10 reference after i checked the emi capacitors and posted the results , i identified the capacitor in question on my power supply , oddly enough it was C10 as well , it had a very high ESR value , so i procedeed to measure all the small caps around that part , in total i found 4 X 4.7uF capacitors and a 47uF one all with high ESR values ranging from 30ohm to 140ohm.
Power supply is alive now , thanks a lot for the help , i attached a picture with the capacitors i replaced , maybe it will help others.
