Author Topic: YOKOGAWA 2558  (Read 1540 times)
Offline kenrameshTopic starter
  • Country: in
YOKOGAWA 2558
« on: August 17, 2018, 11:47:18 am »
need help / suggestion
 facing problem with yokogawa 2558 voltage current standard
display is not stable ,  seven segment led's -8 nos. (red ) flash ( 5 of voltage /current setting & 3 of % deviation) when unit is switched-on .
Flashing stops when the Range dial is rotated , reading dials rotated which cannot be relied.
sometimes the leds are stable but most of the time they go on flashing .
Even the OUTPUT ON/OFF switch, SWEEP switch automatically jump back to off position when the leds start flashing.
what could be the problem.
THANKS in advance
ramesh
« Last Edit: August 17, 2018, 11:57:25 am by kenramesh »
Offline Zucca
  • EE meid in Itali
Re: YOKOGAWA 2558
« Reply #1 on: August 17, 2018, 01:43:29 pm »
Open the device, take a DMM and make some measurement.
Post some pictures and more informations.
Online coromonadalix
Re: YOKOGAWA 2558
« Reply #2 on: August 18, 2018, 01:49:32 am »
Bad suply lines because of failed capacitors, buldged capacitors, bad contacts, bad solders ???  sure some photos would help,  for service manual, i haven't seen any Yokogawa material leaked ?? you can try to ask them
