Author Topic: Yokogawa DL1540C Lithium Backup Battery  (Read 1356 times)
Offline davorinTopic starter
« on: December 11, 2021, 11:14:30 am »
Good morning (o;
Just reorganizing my electronic lab and suddenly discovered when I powered on again my DL1540C scope that it throws now an error message saying the lithium battery is dry:
Tried replacing it with two regular AAA batteries giving around 3.2V instead of 3.6V from the Toshiba ER3V battery...but still complains.
Also haven't found a replacement battery with either the same footprint...and if they have the same footprint the voltage is 3.0V only....
Any other ideas for replacing the ER3V lithium battery?
« Last Edit: December 11, 2021, 11:29:03 am by davorin »
Re: Yokogawa DL1540C Lithium Backup Battery
« Reply #1 on: December 11, 2021, 11:33:26 am »
Okay..tested with an external power supply set to 3.6V....
The DL1540C still complains about the failed lithium battery....
I guess there must be a trick then to reset this error message....
Update: Got it.....Misc -> SelfTest -> Board
Works now with 2 * AAA batteries (o;
« Last Edit: December 11, 2021, 11:50:35 am by davorin »
Offline Per Hansson
« Reply #2 on: December 11, 2021, 02:16:46 pm »
The name of the battery type is 1/2AA
Here is just one example:
https://www.elfa.se/en/primary-battery-6v-2aa-lithium-tadiran-batteries-sl-350-pt/p/16932064
« Reply #3 on: December 11, 2021, 02:22:15 pm »
Ah great, thanks :-)
Wasn't aware the Swiss company extended its business to Sweden (o;
Just have to find out which capacitors causes an ugly smell.....similar to those yellow capacitors in the old Grundig TVs in the 80s....
It's a nightmare to take apart the DL1540C ;-)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #4 on: December 11, 2021, 02:40:06 pm »
Yokogawa, being a Japanese company means I can get these exact batteries off the shelf in Akihabara. It's a Toshiba brand Lithium-thionyl Chloride battery.
Shipping would be interesting though, but any Lithium-thionyl Chloride battery of the same voltage would do the job just fine.
Here's a datasheet for this series of batteries: http://www.gracesemicon.com/pdfs/ER_Catalog_2017.pdf
Sometimes I get a bigger one on flyleads and cable tie it somewhere convenient, usually away from the PCB to help prevent potential leaky battery damage.
« Last Edit: December 11, 2021, 02:43:14 pm by TERRA Operative »
Online factory
« Reply #5 on: December 11, 2021, 03:29:56 pm »
I remember seeing how difficult these are to take apart in this video, oddly the older DL1520 at work had a dead battery but didn't bring up any error message, now i know why calibration never bothered to do anything about it either.
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #6 on: December 11, 2021, 03:45:47 pm »
Bought some of those from farnell some time ago:
https://bit.ly/3oKxFjR
Offline Per Hansson
« Reply #7 on: December 11, 2021, 03:47:31 pm »
Swiss? Their main office in located in Stockholm.
It used to be a really big Swedish distributor, but then they sold out and moved the warehouse abroad, damn shame that was but I digress.
« Reply #8 on: December 11, 2021, 04:43:54 pm »
Well Distrelec is an old Swiss company belonging to the big Daetwyler group.....but then again...not important...
Just good here they have the same battery on stock ;-)
