Author Topic: DER EE DE-5000 LCR meter - damaged  (Read 6278 times)
Offline JaneTopic starter
« on: September 14, 2016, 04:51:08 pm »
I have a  DER EE DE-5000 LCR meter, which was damaged by a  high voltage ( about 220V).
As you can see, from a picture, there are some burnt items( resistors) by  that high voltage .
Does anyone know what values are those burnt resistors?
Besides   DE-5000 LCR can not be turned on now.
Is there any schematic of DER EE DE-5000 available?
Has anyone tried to repair that kind of LCR meter successfully?
Thank you for your feedback
Offline k1mgy
Re: DER EE DE-5000 LCR meter - damaged
« Reply #1 on: September 14, 2016, 05:17:02 pm »
Hopefully the damage is limited to components peripheral to the IC.  Given what I can read from the photograph, even high value resistors fried.  Yikes.
This is such a sweet meter.
I will open mine up (very carefully) tomorrow and get some photos for you.
Never saw a schematic for it, but perhaps the folks in Japan who sell it can help you.
Offline TheBay
  • Country: wales
« Reply #2 on: September 14, 2016, 05:17:51 pm »
Not sure if it's the pictures, but sadly it looks like IC DM 5000-2C has a crack in it and released the magic smoke.
The following users thanked this post: Samogon
Online TheSteve
  • Living the Dream
« Reply #3 on: September 14, 2016, 05:36:07 pm »
It does look like there is a crack in it - right in the spot you'd expect it to be based on where the burnt parts are.
VE7FM
« Reply #4 on: September 14, 2016, 07:43:50 pm »
Thank you all for your replies.
@k1mgy: I will wait for your resistor values.Thank you
Online PA0PBZ
« Reply #5 on: September 14, 2016, 07:53:07 pm »
Forget it, the chip is 100% dead.
Offline Nuno_pt
  • Country: pt
« Reply #6 on: September 14, 2016, 08:23:18 pm »
If the picture is good, I see two cracks, one below the 5000, and another line one the left side.
So the chip has release the magic smoke.
Nuno
CT2IRY
« Reply #7 on: September 15, 2016, 02:25:04 pm »
I checked under microscope and unfortunately that IC is really cracked. Is there any possibility to buy that IC anywhere?
(I think it should be ES51920 by Cyrustek)
Thank you for suggestions
Offline k1mgy
« Reply #8 on: September 16, 2016, 11:09:17 am »
The 0805 resistors are all 1.0K.  The 0603 resistors to the right are 100.0 and 1.0K (left to right order).  See photo.
Good luck!
« Reply #9 on: September 16, 2016, 05:55:29 pm »
@k1mgy: Thank you very much for sending those resistors values
Unfortunately that DM5000-2C-02( should be ES51920 by Cyrustek) is also cracked. Do you happen to know where it can be bought?
Offline k1mgy
« Reply #10 on: September 16, 2016, 07:19:26 pm »
No, sorry.  You might check with the manufacturer.
However I suspect if this is replaced it will need recalibration.
/m
Offline markce
« Reply #11 on: September 16, 2016, 08:15:17 pm »
The IC is supposed to be a Cyrustek ES51920 (?), which is part of the LCR meter chipset.
Given the price of the DER EE5000, I think you better buy a new LCR meter.
The DER EE5000 definitely is not good for in-circuit measurements.
Offline nanofrog
« Reply #12 on: September 17, 2016, 05:07:30 am »
Whether you're testing components in or out of circuit with the DER EE DE-5000, capacitors must be discharged first as there's no protections for the meter if you don't.
Offline kripton2035
« Reply #13 on: September 17, 2016, 07:45:34 am »
try to ask for a sample of each at cyrustek sales representatives.
they sended one chip to a member of this forum that had the chip burned like you.
worth a try, otherwise these chips are not for public sales, you will have to buy another dm5000
(or a protected esr meter for live measurments !)
