Hey there,
I'm attempting to repair a Yorkville MP6, multichannel powered mixer. The problem is that only a very faint signal passes through.
I've narrowed down the problem to the power amp section.
Schematic attached, with problematic component circled in red.
Signal is reaching the optocoupler (U3) but not passing through. The resistance of the photocell side, in circuit, is 22k when powered on, and 81k when powered off. The spec sheet for the optocoupler calls for an max resistance of 2.5k when LED is on, and min resistance of 1M when off.
The LED side of U3 has a voltage drop of 12-13V, while I believe the spec sheet calls for max 2.5V? Not sure if this indicated the problem is elsewhere.
When I jumper the resistor side, the signal passes through and there is amplification, so I don't think there are any other issues with the amp.
I pulled U3 from the circuit and my multimeter across the LED is reading OL resistance both ways. Even out of circuit, shouldn't I see around 1M ohms anode to cathode according to the spec sheet?
My questions are:
(1) Originally thought the zener diode ZD5 was to be a voltage regulator and the LED would see 4.7V, is this not the case? I replaced the diode thinking it was faulty but nothing changed.
(2) Should I go ahead and replace U3? NSL-28AA seems to be out of production, not sure if I can find a suitable replacement.
(3) What should next troubleshooting steps be?
Any help is appreciated, feel like I'm very close on this one.
Thanks!
