Author Topic: YST-SW800 Yamaha Subwoofer SMPS repair help  (Read 974 times)
Offline Hman545Topic starter
« on: September 08, 2021, 03:09:14 am »
Hi guys, I have a subwoofer that I'm trying to repair, it has a faulty SMPS and need help finding suitable alternative power transistors.
I've got the repair manual and found 4x blown power transistors and 2x resistors blown open.
They are:
2x 2sc4140 (TO3P)
2x 2sc4163 (TO-220F)
Can't find those transistors new anywhere, so I've found alternatives.
https://au.element14.com/on-semiconductor/fja13009tu/transistor-bipol-npn-400v-to-3p/dp/2450767
and
https://au.element14.com/on-semiconductor/fjpf13007h2tu/trans-npn-400v-8a-150deg-c-40w/dp/3368627
I only understand the bare minimum how transistors work and what all the specs mean as I'm still learning.
Are the above replacements suitable or should I use something else?
(Also before anyone asks, I'm aware of the dangers of working on mains voltage equipment and am taking relevant precautions.  :))
Offline David_AVD
Re: YST-SW800 Yamaha Subwoofer SMPS repair help
« Reply #1 on: September 08, 2021, 03:17:28 am »
Check the price on a replacement board (from Yamaha Aust) as sometimes they are surprisingly cheap and make repair not worthwhile.
« Reply #2 on: September 08, 2021, 03:49:52 am »
Hmm, I'm fixing this sub for fun and as a learning experience so I'd rather try repair it.
