Author Topic: Z-Wave lock depletes batteries  (Read 1458 times)
Offline danshtrTopic starter
« on: January 22, 2019, 04:27:22 pm »
Hi All,
My Z-Wave door lock is using 4 AA batteries. They sometimes hold for weeks and sometimes they don't hold even for 48 hours.
When the batteries deplete in a short period of time, I notice that only two out of 4 batteries are depleted, the other two are measuring 1.55V.
Any idea how come batteries that are in series can deplete at a different rate?
-Dan
Offline Armadillo
Re: Z-Wave lock depletes batteries
« Reply #1 on: January 22, 2019, 05:02:35 pm »
You didn't say if the batteries are all from the same NEW batch, so could be 2 old and 2 new.   ;D
« Reply #2 on: January 22, 2019, 05:17:08 pm »
All new batch. Tried two different vendors: Amazon and Energizer (bought from Energizer store at Amazon).
Online edavid
« Reply #3 on: January 22, 2019, 05:50:06 pm »
There is probably an additional connection to the center tap of the battery string.
The following users thanked this post: danshtr
Offline Armadillo
« Reply #4 on: January 22, 2019, 06:31:57 pm »
The best is to confirm it with a multimeter set to ohms [if not auto then set to high ohm range].
With the batteries out, black probe to known negative terminal and red probe to positions as shown.
Only the known Positive and Negative should indicate a ohms reading.
otherwise you may have a hidden circuit or a conductive leak from previous battery leaks, for example.
« Reply #5 on: January 22, 2019, 07:12:37 pm »
I have tested on all points, all showed out of range
EDIT - forgot to add: the voltage on the "9V battery clips" is 6.3V
« Last Edit: January 22, 2019, 07:16:25 pm by danshtr »
« Reply #6 on: January 22, 2019, 07:19:27 pm »
I might have inserted the battery holder upside down.
I can not confirm or deny that the batteries had contact with the PBC directly...  |O
Offline Armadillo
« Reply #7 on: January 22, 2019, 07:20:10 pm »
I forgotten to add;
Your AA battery compartment must be hook/connected to the Z-Wave Lock for the measurement to be Correct, Otherwise you will be measuring empty space.
But luckily, there is no conductive leak.
Connect the empty holder into the circuit and measurement again to confirm.
Offline Armadillo
« Reply #8 on: January 22, 2019, 07:21:05 pm »
OK at least you have found the problem and solution.
