Author Topic: Zener 3T 4148 voltage rate  (Read 1080 times)
Offline sdancer75Topic starter
  • Country: gr
« on: February 28, 2021, 06:56:48 pm »
I couldn't find anything....
I need to replace a burned zener. It is marked 3T 4148 if I read well.
How much is the reverse rating  voltage?
Thanks
Offline madires
  • A qualified hobbyist ;)
Re: Zener 3T 4148 voltage rate
« Reply #1 on: February 28, 2021, 07:06:00 pm »
Maybe a standard 1N4148, and not a Zener?
  • Country: gr
« Reply #2 on: February 28, 2021, 07:42:48 pm »
It seems like a zener. Orange glass is classic package for zeners but how can I be sure? Its from smps and it's on the primary side just before the optocoupler
Offline madires
« Reply #3 on: February 28, 2021, 07:50:41 pm »
Then reverse-engineer that part of the circuit to figure out what the diode is meant for.
  • Country: gr
« Reply #4 on: March 01, 2021, 06:07:34 pm »
Looking again the part under my microscope, I can say it says ST4148 and not 3T4148 I mentioned originally. I google it and I found that it's a switching diode despite the fact that many alibaba and aliexpress webpages describe it as zener.
So, I suppose I can safely replace the part with the 1N4148. Do you agree?
Offline madires
« Reply #5 on: March 01, 2021, 06:21:55 pm »
Yep!
The following users thanked this post: sdancer75
Offline wraper
  • Country: lv
« Reply #6 on: March 01, 2021, 06:26:07 pm »
It's not solely for zeners. If it has 4148 written on it, it's 1N4148. Zeners have different marking.
Offline fzabkar
« Reply #7 on: March 01, 2021, 06:34:49 pm »
See the references to ST4148 in the following circuit diagrams:
https://www.abcelectronique.com/forum/attachment.php?attachmentid=66088
