Author Topic: Zener Planar Diode ZPD  (Read 865 times)
Offline gmcTopic starter
« on: November 21, 2022, 10:24:07 pm »
I have a faulty ZPD 4V3 diode. According to the data sheet it's a zener planar diode which is a term I've not heard of before (planar)
Data sheet here:
https://www.tme.eu/en/details/zpd4.3-dio/tht-zener-diodes/diotec-semiconductor/zpd4-3/
What's the difference between this a normal zener diode. Can I use a BZX55C4V3 for example it's place?
https://www.vishay.com/docs/85604/bzx55.pdf
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Zener Planar Diode ZPD
« Reply #1 on: November 21, 2022, 10:28:22 pm »
All diodes are planar; it might've been a term of note in the early years, perhaps it's a very old product line?
Looks completely identical to the BZX series yes.
Seven Transistor Labs, LLC
The following users thanked this post: gmc
« Reply #2 on: November 21, 2022, 10:42:02 pm »
Thanks. Learnt something new.
It's a diode from the early 80's so that would explain the terminology.
Offline DavidKo
  • Country: cz
« Reply #3 on: November 23, 2022, 11:44:22 am »
The name was used to distinguish them from point contact diodes. Today 99% of diodes are the one produced by planar technology.
Offline T3sl4co1l
« Reply #4 on: November 23, 2022, 04:45:05 pm »
I would expect it's a lot higher than that... but once you get into the question of "how many nines?", clearly there's a lot, regardless. :D
Offline gamalot
  • Correct my English
    • Youtube
« Reply #5 on: November 23, 2022, 05:09:09 pm »
When I was a kid, the most common one in China was point-contact germanium diode 2AP9.
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
