Author Topic: ZT–702S Multimeter/Oscilloscope Reading Pulsed 6.3 V heater supplies!  (Read 464 times)
Offline Chris56000Topic starter
. . .I'm providing technical assistance down at a local Retro Arcade near where I live, and I'm currently having difficulty with one of those Zotek ZT–702S not reading the pulsed 6.3 V CRT heater supply on C.R.T. arcade game display chassis – it detects the frequency as "15.84 kHz" but the voltage shown is negligible!
. . .Have I got a faulty instrument or has it got such a poor frequency response that the so–called "true–r.m.s." converter can't read it?
. . .Will the ZT–703S read this type of supply in Multimeter Mode?
Chris Williams
« Last Edit: October 28, 2024, 02:58:03 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline abeyer
Re: ZT–702S Multimeter/Oscilloscope Reading Pulsed 6.3 V heater supplies!
« Reply #1 on: October 28, 2024, 06:04:22 pm »
The specs say: Frequency response of ACV: 40Hz-1kHz
https://zotektools.com/products/zoyi-zt-703s/
« Reply #2 on: October 28, 2024, 06:51:41 pm »
. . .It can't be a very good so–called "true–rms" converter in it, my UT61E is only quoted up to 1 kHz in the leaflet I got with it, but the UT61E can read that type of supply – I took it down there today and tried it on one of their C.R.T. displays and read back 6.1 V!
. . .The Arcade Staff would buy me a suitable meter if they're not horrendously expensive – can anybody suggest anything quoted up to 15 kHz or better – or would I be better with an analogue True RMS Meter for these supplies?
Chris Williams
« Last Edit: October 28, 2024, 06:56:13 pm by Chris56000 »
Offline Xena E
« Reply #3 on: October 28, 2024, 06:54:56 pm »
I assume the heater being a winding on the sweep transformer: the 15*** kHz would indicate that.
To accurately measure the heater power it can be compared with a suitable hot wire or thermionic measuring instrument.
If niether are available, compare the emission of a suitable indirectly heated valve between being powered from 6.3 volts DC and the HF source, this will be best measured by comparing the current in short circuit between the cathode and first grid.
Most meters won't make any sense of the hf frequency or waveform from the sweep transformer.
X
Offline timop
« Reply #4 on: October 28, 2024, 08:58:02 pm »
I would recommend the Brymen BM869s DMM. The AC+DC true rms bandwidth is 100kHz, and the inputs are rated CAT IV/1000V. IMHO it's a reliable and robust meter that provides a lot of features and good accuracy for the price.
Offline beenai2018
« Reply #5 on: October 29, 2024, 06:33:23 pm »
Chris Williams
Are you sure about your ut61e bandwidth ?Its accuracy is specified to 10Khz in the manual.
