Author Topic: Meanwell RD-125-2412 versus RD-125-1224  (Read 1721 times)
Offline RustyShacklefordTopic starter
« on: August 14, 2018, 05:03:48 am »
These are both dual-output switching power supplies, with 12vdc and 24vdc outputs.   I can't figure out the differences, and the datasheet mostly gives hints.
https://www.meanwell.com/Upload/PDF/RD-125/RD-125-SPEC.PDF
It looks like the load regulation is better for "channel 1" (the first of the two designators in the part name after "RD-125-").   There is also suggestion that only channel 1 has adjustable output voltage (a range is listed for it, but not for channel 2').
Maybe I've already answered my own question, but I wonder what else there is ...
« Last Edit: August 14, 2018, 05:06:18 am by RustyShackleford »
Offline helius
Re: Meanwell RD-125-2412 versus RD-125-1224
« Reply #1 on: August 14, 2018, 06:20:27 am »
It is typical for multi-output switching supplies to regulate most precisely on only one of the outputs, because the user requires that output to be more stable, for instance in a mixed analog/digital device the analog supply should be more cleanly regulated than the digital supply.
« Reply #2 on: August 14, 2018, 11:36:25 pm »
It is typical for multi-output switching supplies to regulate most precisely on only one of the outputs, because the user requires that output to be more stable...
Thanks.   Similarly, do the you interpret the datasheet as saying that only Channel 1 has adjustable output voltage ?
Offline helius
« Reply #3 on: August 14, 2018, 11:59:06 pm »
Yes. In the picture you can see there is only one V+ ADJ on the unit, probably a single-turn cermet pot. It makes sense to only provide adjustment of the higher precision output voltage—anyway, it is a "set it and forget it" type of adjustment.
The following users thanked this post: RustyShackleford
« Reply #4 on: August 15, 2018, 04:48:58 am »
After all that, it turns out I can get both a 100watt 12vdc unit and a 100watt 24vdc unit, for the same price (in Meanwell's LRS series).  Not as compact, but I don't care right now.
Since you seem to know about these ... Two similar (smaller) Meanwell units just died on me (I think I might've shorted 'em together briefly, but it was just after a lightning bolt came very very close to the house, so who knows).   Anyhow, when I power either one up, the voltage comes up and immediately drops out (over many seconds if there's no load).  Is that something recoverable ?
Offline helius
« Reply #5 on: August 15, 2018, 05:12:00 am »
I don't know. These types of supplies should be short-circuit protected, although they are not advertised as crowbar protected.
This means that back-feeding higher voltage into the outputs may cause damage.
« Reply #6 on: August 15, 2018, 05:42:26 am »
Yeah, but they both got whacked.  The lightning bolt didn't even make the lights flicker, though it knocked out the whole neighborhood's cable for a day or so.  But they're not stone dead, and the symptoms are remarkably similar.  It's a head-scratcher ...
Offline capt bullshot
« Reply #7 on: August 15, 2018, 06:34:01 am »
Lightning damage can be very obvious (direct hit) or quite subtle if the strike was e.g. some 100m in distance.
Your symptom looks like the main regulating path is damaged, so the output voltage rises above the maximum and the over voltage protection kicks in (which just shuts down the primary side controller until the next power cycle).
« Reply #8 on: August 15, 2018, 09:01:49 pm »
I can replace 'em both, with ones with somewhat higher power, for $30 or so.   Just wanted to check if it was something simple.
