Unboxing my new Hudl2.
It certainly has the look and feel of a quality product as mentioned in the reviews. The box is very Apple like in that its nicely designed. You pull on a ribbon to withdraw the inner carton from the outer shell ! The Hudl is inside a quality sheath to protect it and the screen protector carries all manner of information regarding the port locations etc. This thing has a micro HDMI output on it
The inner carton also contains the A to Micro B USB cable and the 5V/2A charger, each in their own storage section.
All this makes for a good first impression...... remember, this is a tablet sold under a supermarket banner and at a knock down price. Me thinks the margins may have been an issue and this may have lead to deletion of the project. Tesco wanted to make a big splash with the HUDL, and I believe they did. That does not make it a viable product if the bottom line does not show a healthy profit though.
I am charging the unit now and all looks to be good. Once it is set up I will be checking to see if the FLIR ONE Gen2 thermal camera works with it. The 1.8GHz Quad core Atom microprocessor may, or may not, have enough grunt for that application. It may have to do ARM to X86 translation for the FLIR APP and that could be an issue if it impacts speed too much.
All I can say is that I am glad I have this little tablet. I have an Apple Air2, but I don't like to put that at risk. Use in the bath tub being one 'no go' area
. I currently use an HP Slate 7 for that scenario
The HUDL2 has a nice silicone case covering to protect it from life's knocks as well.
Fraser
