Sequre plans to sell a wider variety of soldering tips in the future, but it should be understood that Sequre does not manufacture soldering tips and resells or equips soldering irons, including tweezers, with not original JBC, but alternative, normally functioning soldering tips - you can buy 3 mm (C120-003) and 5 mm (C120-005) blade cartridges in the Sequre store for affordable price right now.
HT140 fits JBC 120 and some C210 series soldering tips. For example, two C210-002 (C210-IS) can be used always just now as they are identical to C120, or C210-018 (C210-K) soldering tips can be used to de-solder larger components instead of special C120 in most cases. The original two JBC C120 soldering tips C120-008 and C120-007 will cost almost the same as this set of tweezers.
