Author Topic: 5V Power Supply who output a "clean" 5V Power for SDR?  (Read 3108 times)
Offline Lord of nothingTopic starter
  • Country: at
« on: June 03, 2019, 02:33:48 pm »
Hi
I ordered an USB Isolator who should work with my SDR. Sadly on <30Mhz my Power supply produce to much Noise. So Is there a 5V Powersupply on the European Market who filter, block,... or what ever every noise who could come via the Power Cable?
 :-// Maybe some Lab Power Supply?
The USB Dongle dont draw that much power so for that nothing special is necessary.
The main part is no additional noise should get truth the Power cable.
Made in Japan, destroyed in Sulz im Wienerwald.
Offline madires
  • A qualified hobbyist ;)
Re: 5V Power Supply who output a "clean" 5V Power for SDR?
« Reply #1 on: June 03, 2019, 02:51:12 pm »
You could try an LC filter at the output of your PSU. Start with 10-33µH and 220-470µF. Or do you have a linear PSU with transformer?
  • Country: at
« Reply #2 on: June 03, 2019, 03:02:15 pm »
Nope nothing.
Offline Gyro
« Reply #3 on: June 03, 2019, 07:18:47 pm »
Ditch the DC-DC converter on the USB isolator. Then purchase an old transformer based wall wart with 9V output from ebay and add a 3 terminal 5V linear regulator.
This is the approach I took with my 16 bit Pico ADC216 scope and USB isolator with good results.
Best Regards, Chris
Online Bud
« Reply #4 on: June 03, 2019, 11:06:46 pm »
A USB rechargeable juice pack for cell phones.
  • Country: at
« Reply #5 on: June 08, 2019, 05:16:36 pm »
So next week the Isolator should arrive here.
How should I know if the use that?  :-//
Offline Gyro
« Reply #6 on: June 08, 2019, 08:34:12 pm »
They will almost certainly be second-hand, eg. from an old modem, cordless phone etc. Weight and volume are another clue. Another one is that mains input voltage and frequency will be specified over a small range, eg. 230VAC +/- 10% 50Hz, rather than, say, 100-240V. Lastly their may be a reference to the supply being thermally fused.
A couple of example UK listings:
https://www.ebay.co.uk/itm/9V-Mains-AC-DC-Plug-Power-Adapter-BS0900350-For-Electric-Keyboard-tested-used/392304456528
https://www.ebay.co.uk/itm/US-Robotics-SP3a-9V-1000mA-1A-AC-DC-Modem-Power-Supply-Mains-Adaptor-PSU-UK-Plug/372683226233
EDIT: Actually the second one is a 9V AC output, a very definite clue!
« Last Edit: June 08, 2019, 08:37:27 pm by Gyro »
Best Regards, Chris
Offline ebastler
« Reply #7 on: June 10, 2019, 06:49:13 am »
Do you actually know that the noise is coming from the power supply?
Before you chase a used transformer-based power supply and tinker with adding a linear regulator, I think Bud's suggestion above is a great one, at least for testing: Use a USB power bank (rechargeable battery) to power your SDR and cofirm that the noise goes away.
Offline ogden
  • Country: lv
« Reply #8 on: June 10, 2019, 07:02:35 am »
Unfortunately most USB power banks are no better than phone chargers/adapters - because they have switching boost (or buck) converter inside.
« Last Edit: June 10, 2019, 07:08:00 am by ogden »
The following users thanked this post: ebastler
Offline ebastler
« Reply #9 on: June 10, 2019, 07:10:42 am »
Duh -- didn't think of that.  :palm:
The marvels of modern technology... Thanks for pointing that out!
  • Country: at
« Reply #10 on: June 10, 2019, 10:39:20 am »
When I disconnect the power supply from my Laptop most noise are gone.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #11 on: June 10, 2019, 04:29:42 pm »
why no trivial linear PSU ? Heats your flat and keeps noise out.  ::)
Offline mariush
« Reply #12 on: June 10, 2019, 04:45:27 pm »
You could make your own linear power supply
Get a transformer that outputs 6...7.5v AC
Get a bridge rectifier or 4 diodes to convert the AC voltage to DC
Get a big capacitor to smooth the output
Get a linear regulator to regulate the voltage down to 5v
Here's transformers that would fit your needs, just get one that can provide the current you need : long link to transformers at tme.eu
bridge rectifier - any bridge rectifier would do, as long as it has the current rating
capacitor... 3300uF 16v should be enough, it's a common value used in atx power supplies so should be easy to find
example :
Offline Gyro
« Reply #13 on: June 10, 2019, 05:33:13 pm »
Yes, you can absolutely do that too. Buying a second hand transformer based wall wart off ebay just saves you the hassle of the mains side and enclosure and is probably cheaper. Just add the 7805 and capacitors of your choice.
Best Regards, Chris
  • Country: at
« Reply #14 on: June 12, 2019, 10:06:42 am »
Hi
Today I received the Isolator. Sure I dont have a Power Supply yet.
Here 2 Screenshots.
1) with the Isolator: https://www.delock.de/produkte/S_62982/merkmale.html
2) with the USB Hub: https://www.delock.de/produkte/678_extern/63311/merkmale.html
Both are powered by the Latop (who is a Power Plug connected)
« Last Edit: June 12, 2019, 10:11:11 am by Lord of nothing »
Online The Soulman
  • The sky is the limit!
« Reply #15 on: June 12, 2019, 11:41:06 am »
Does your laptop have a grounded plug? if so, is it connected to a properly grounded outlet?
  • Country: at
« Reply #16 on: June 12, 2019, 12:53:24 pm »
Yes
And I guess Yes.
Offline madires
« Reply #17 on: June 12, 2019, 02:45:23 pm »
Have you already tried to power your SDR via a different wall outlet (or different phase, or different room)? I had a similar issue with a SW receiver which was resolved by moving the receiver's linear PSU to another socket. I've tried a cap between the PSU's negative output and PE, also a direct connection to PE. Slight changes, but still no real improvement. My guess is that the noise was created by the PE current from computer and monitor SMPSUs (Y caps) powered via the same socket. Moving the receiver's PSU to another socket, not daisy-chained with the former one, without any SMPSUs worked wonders in my case. Solving noise problems can be quite time consuming, but also very educational.
