There are 2 variants for that 907 handle, one with thermocouple and one with a ptc as temp sensing method, on the video says that the heater resistance it's 14ohms and for the thermocouple it's 2 ohms (it should be less, it's basically a short); for the second variant the resistance of the heater it's around 4ohms and the ptc resistance it's around 40ohms at room temp (it will change with temp, so you can expect more resistance). So maybe you are using the wrong handle for your station.
