The Master LED's do have their own internal drivers, I do know that much.
Just reading the "datasheet" for them, they don't explicitly state they run on 12VDC, just they're compatible with most normal downlight transformers ..
However, my guess is the AC is just instantly rectified once it's inside the unit, which in the case of 50Hz, would give 100Hz. I'd also suspect they don't make different versions for AU and the US, so assuming they can handle 60Hz as well, that'd be 120Hz.
So, I suspect if I PWM them at 122Hz, I should be safe ... maybe
