Hi All,
I recently purchased a 0.65x to 6.5x microscope from aliexpress and I am using it with a 0x5 Barlow lens and standard 10x eyepiece. This give me a really nice 3.25x to 32.5x range which I really like. I temporary had a standard 0.7x to 4.5x microscope which I returned because I really did not like the double arm stand.
One thing that is different with this new one is the crazy working distance, we are talking over 200mm. At first, I was really happy about that but quickly realize that there is some downside to this, mainly having hard time finding a comfortable position and mostly, the lighting problem.
Having lens being so far from the work-piece mean the angle of the light is way smaller which create more glare. Simply holding the light about 50-80mm lower dramatically improve the image quality.
I could simple 3d print a extension tube to lower the light, but if there is a way to reduce the working distance, without loosing my 3.25x range, that would be fantastic. So the question is: Is there a way to reduce a microscope working distance ? A other solution might be some kind of light diffuser or larger led ring, I waiting for your suggestions.
Thank you
