FX-100 has arrived. Short review based on ~ 30 min of play time with a single very fine JL02 bent conical at 450C:
Gut shot pics here:
https://imgur.com/gallery/gHf5Sqv No, I'm not pulling the boards out a disconnecting all that wiring just for photos.
I'm not AvE so any teardown I do will be inferior, but I can tell you that the entire housing is a cast zinc alloy (like a Zamak variant) of excellent quality. It is designed such that the housing serves as a large passive heatsink, so no need for a fan. Even the faceplate, which you might suspect of being plastic is actually the same die cast alloy. (the ejector pin marks on the castings are proof of die casting vs say investment casting).
I love that there is no fan, nor any need for one. I can tell you that the unit has some very mild transformer hum that my FX-951 doesn't have. You have to listen for it (it's subtle) but it's definitely there.
The handpiece is quite a bit slimmer and lighter than even the excellent FX-951. As approximate comparison for precision and control, I will make the following comparison of handpieces:
FX-100: Scalpel
FX-951: Small pocket knife
FX-888: Large chef's knife
The FX-951 has an excellently comfortable handpiece, but the FX100's handpiece is just better. (I know these handpieces have model numbers, but that's just confusing as to which goes with which, so I'll refer to them by station). The FX100's piece is not just slimmer, not just shorter tip reach, but the piece itself is lighter and has a notably lighter cord. Which means it feels nearly weightless in hand. The 951 feels light in hand. The 100 feels nearly absent in hand. I'm sure either of them is all-day comfortable.
The T31 tip cartridges for the 100 are just TINY. Like super short as well as thin. This is certainly a big part of the near-weightless feel in hand.
I dabbled a bit with a very small JL02 bent conical (needle like) at 450C/840C temp. Even with the tiny heat capacity of such a small and long tip, it had no problems melting a puddle of solder on a penny. It did take a little while though, because this is perhaps the worst heat capacity tip you can get for the station. It's long and very thin, the opposite of a high-heat tip:
As additional evidence of this being a very low-heat tip, I'll point out that the station's display of load never showed it approaching full power. In short, the tip is just not capable of passing enough heat to load the station. You'd never use a super long and thin tip like this for any substantial mass anyway, but it was indeed capable of melting solder to a penny. And it even melted solder to a potentiometer back like this:
For a tiny tip to be able to punch above its weight so well, you know that there has to be some good thermal performance.
Side by side comparison to my 951 with the latter set also to 450C (way hotter than I work) and the lowest heat capacity tip I have for the 951, the 951 wins in the melt-solder-to-penny race. But my 951 tip is a shorter bent chisel (JD14) and is significantly higher heat than this JL02tip is. It *should* have been a blowout in favor of the 951, but instead it was closer than it should have been.
Out of the box with the JL02 tip, the FX100 feels almost like a microsoldering setup. It's just a micro setup that can handle nasty multilayer ground planes if you give it a big hot tip.
I'd be remiss if I didn't mention the MUCH BETTER user interface on the FX100. Three simple buttons, no annoying chirps all the time. Sleep mode AND auto shutoff (concurrently!), none of that stupid security key business. Yes, it's got super pro features like tracking the cycles per tip, automatically detecting what tip you have in, etc. But that stuff never gets in the way. The LCD with active indication of tip loading is far preferable to the little flickering dot LED of the 951 that shows heating cycles.
I'll sum up the FX100 advantage over the 951 as:
-small gain in thermal performance
-substantial gain in pleasure to use/ergonomics
-enormous gain in user-friendliness of interface and display.
I suppose that the hottest tip for the 951 as its highest setting might have more heat output and better performance than the 100 is capable of. But in terms of power-to-weight, it's no contest-- the FX100 gives you hot rod performance like that in a lighter and slimmer and more enjoyable package. It just feels like a pro lab instrument where the plastic housing and bright yellow graphics of the 951 feels a bit more consumer-oriented.
I still feel like the 951 might be a better choice overall because it's more versatile. Lots of tip shapes including tinned-face-only bevels that don't (yet) exist in the T31 tip range.
Deciding which one to keep is going to be a real challenge.
