Author Topic: Advice on The BGA Rework Machine  (Read 8315 times)
Offline tfmTopic starter
« on: September 07, 2015, 08:14:47 am »
Hello,
I am a professor at an University, Electronic Engineering, and I am looking for a rework machine, particularly capable of reliable BGA reworking. I came across The BGA Rework Machine, and its construction and control seemed quite good.
http://www.amazon.com/The-Rework-Machine-Made-Station/dp/B00K4MHUYS
http://www.thebgareworkmachine.com/
However, I haven't really seen many reviews or comments about it, and it is a $2500+ investment. Can any one (owner) provide some information?
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
Re: Advice on The BGA Rework Machine
« Reply #1 on: September 07, 2015, 08:48:45 pm »
Take a look at this one, too. More expensive but the references to NASA made me pick the ZT-7. So far, I have had no trouble with soldering and desoldering BGAs between 15x15mm and 31x31mm. http://www.zeph.com/bgarework_stations_systems_qfn_smd_hot_air_repair.htm
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Online PlainName
  • Country: va
« Reply #2 on: September 07, 2015, 09:41:49 pm »
I know nothing about these, but I am gobsmacked that something of this price requires you to manually nudge a mini-table with legs on around the bench to precisely align stuff! I would have expected at least an X-Y table, preferably with micrometer adjustment.
« Reply #3 on: September 08, 2015, 03:26:04 am »
Thank you very much for the suggestion.
I haven't read through it, but I'll most likely go for it. Can I ask what is your equipment set? I was considering a ZT-7001 System. I am not sure if a HOT AIR PENCIL ZT-2 would be handy enough to justify the investment. Any other accessory you consider worth?
« Reply #4 on: September 08, 2015, 03:30:20 am »
That caught my attention too, although they seem to go for high quality parts, price vs benefits relationship is a bit odd. Besides, suggestion from John_ITIC showed a more mature, solid solution.
« Reply #5 on: September 08, 2015, 03:41:33 am »
Any comparison with PDR machines? Those seem well designed and built solutions too.
Offline John_ITIC
« Reply #6 on: September 08, 2015, 06:39:53 am »
I have this exact system: http://www.zeph.com/bgarework_stations_systems_qfn_smd_hot_air_repair.htm
I actually picked up a ZT-7 with the Big Grid air bath (lower pre-heater) on Ebay for 50% of new price. I bought it because I otherwise had no way to deal with the BGAs on my newer prototype designs (USB and PCI Express Protocol analyzers). I have bad experience with IR-based systems because of uneven heating; connector can burn while other spots are cold if in "shadow". Supposedly, this is what forced air rework stations do not suffer from. Almost all of the BGA rework systems sold on the market are IR based so the design of the Zephyrtronics system appealed to me. I have not yet managed to burn any boards and it is very easy to remove and resolder BGAs with the ZT-7.
As far as re-balling removed BGAs goes; do not use the Zephyrtronics BGA hot-stencils and jigs for rework. Balls do not get centered on the pads correctly, gets stuck in the stencil etc. Perhaps the non-alignment is due to the airflow from the upper heater element. http://www.zeph.com/reballing_kit.html
Instead, get this type of reball kit and use a hot-plate for reflowing the balls: http://www.ebay.com/itm/Bga-Reflow-Tools-Kit-90X90Mm-Reball-Station-Universal-Stencil-Flux-Solders-/131322800143?hash=item1e9372e80f
Here's a summary of my re-balling experiences: https://www.eevblog.com/forum/projects/bga-reballing-stencil/msg748309/#msg748309.
Sorry, I have no knowledge of the PDR machines but since IR-based I suppose not as good as the ZT-7: http://www.pdr-rework.com/
« Last Edit: September 08, 2015, 06:48:05 am by John_ITIC »
Online Shock
« Reply #7 on: September 08, 2015, 03:04:36 pm »
They posted a video right on that page why they have separate fixtures (for flexibility).
Online PlainName
  • Country: va
« Reply #8 on: September 08, 2015, 03:56:20 pm »
Being independent, swappable, flippable, inclinable and all that other stuff doesn't preclude it also being indexable :). I am just surprised that the BGA apparently needs very accurate location, but moving that crable by hand around the bench is apparently accurate enough. The two things don't mesh in my mind. But I haven't used one so...
« Reply #9 on: September 08, 2015, 09:20:40 pm »
This is more or less the same drwaback I saw on The BGA rework machine. I haven't found the NASA document/manual explaining how to do it. They posted a video showing it, but I don't know...
