Contact locator is a good idea, but I haven't seen any SN-** crimping tools on the market that have it.
Yes, I already said that.
(Trust me, unless you work for a crimp tool company, I’m sure I’ve spent more time looking than you have!
Maybe it's because of patent issues.
I sorta doubt it, insofar as the concept of a locator is nothing new, and the styles of tool the Chinese copy are mostly rather old designs whose patents have likely already expired. (And the only ones that do have locators — the Han-D and MC4 ones — are actually clones of
recent Knipex designs, so even if those are patented, the Chinese tool makers don’t seem to care.
I spent a whole night crimping DuPont 2.54mm Terminals. This is what I got.
In the picture, the terminal at the top was crimped with the SN-025, and the one at the bottom with the TZ-4228B.
I deliberately chose a thick wire with a 1.6 mm outer diameter to test them. I'd say the SN-025 performed much better than the TZ-4228B. The latter crimped the terminals with an overly thick barrel around the insulation, which sometimes made it very difficult—or even impossible—to fully insert the terminal into the housing.
For SN-025, in most cases, the terminal can be inserted smoothly all the way into the housing.
Neither crimp looks great, but while I’d say the SN-025’s looks to be more precise, we’d really need to see a properly-done crimp to be sure. That one has the wire trimmed too short, and not fully inserted. (Or it is fully inserted, but the insulation is cut uncleanly so we can’t see whether the insulation is fully crimped or not.)
The SN-025's die has higher precision and a better finish. Its overall build quality is also better. I only need to squeeze the handles lightly to crimp.
The build quality of the TZ-4228B is actually similar to that of $5 crimping tools, but it costs $12. This brand also sells standard SN-type pliers for around $5. I guess the higher price is just because tools that can crimp DuPont terminals properly are hard to find.
Yeah, the build quality of the TZ-4228B is disappointing.
At the end of the test, I was surprised to find that the upper and lower dies of the TZ-4228B aren’t aligned!!!
Indeed, I think their dies are let down by a really cheap handle. At my old work, we bought several of them, and some had much better die alignment than others. It’s just really poor precision and quality control in the handle.
I tested these pliers on smaller terminals, and my conclusion is that the IW-3220M is the best all-around.
It has a thin 2.6 mm die, which works great for MX 1.25 and SH 1.0 terminals. For these tiny terminals, I have to use my non-standard crimping method. But I can't use that method with the SN-03BM because its 3 mm die is too thick, so I’ve never succeeded in crimping these terminals with it.
Speaking of PH 2.0 terminals, the IW-3220M, SN-01BM, and SN-02BM all crimp them well, except the M-shaped section ends up too flat and wide. Still, the terminals can fit into the PH 2.0 housing without issues.
I'm gonna keep the SN-025 and IW-3220M, and return the rest.
Nice, thanks for the info.
What is your “nonstandard method”?
Re: “flat and wide” — YES! This has been my observation with practically all cheap Chinese crimp tools: they crimp too flat and wide compared to the original tools. I can only assume that this is easier to manufacture, but it really reduces the crimp quality.
