Why would you expect DCV ranges to indicate AC voltage? Does it give an alert when set to other functions like ohms, continuity or capacitance? If it does, then it should do the same in VDC mode for consistency sake. If it does not, then I don't see why you would expect VDC to warn you about AC voltage. Just set it to AC + DCV if you're interested in both.
