Author Topic: Aixun CM30 Automatic Tip Cleaner Teardown and Review  (Read 1509 times)
Offline diggerTopic starter
« on: October 17, 2024, 01:31:06 am »
https://www.eevblog.com/forum/reviews/hakko-ft-720-automatic-tip-cleaner/msg5651667/#msg5651667
i got one from aliexpress for $88 shipped.
compared to yihua 200C that i got for $50 from amazon: i would go for the aixun cm30, no question. the build quality is better. the window is nice so you can see what you're doing. it also has a larger aperture for easier maneuvering. i prefer the arrangement of the brushes on the aixun, and also it feels a bit draggier (so perhaps stronger) which was surprising because the bristle density on the yihua looks higher. maybe the gap between the brushes is different or something. the tip sensing seems a little more responsive on the aixun as the yihua uses IR. the actual cleaning performance is about the same though.
it uses capacitive sensing or something for tip sensing, and it's plenty sensitive. it actually detects the iron tip (or a screwdriver or whatever) just outside of the aperture, and it will also detect a finger or other metallic or moist things. i did not find that it was oversensitive or twitchy. it just works well.
i am 'impressed' with the mechanical engineering. it doesn't seem like they were optimizing super hard for cost, and i chuckled several times as i took it apart. it seems overbuilt and too well made for what it is. i wonder if the performance or the UX is in any way worse than a fancy tip cleaner from JBC. never used one of those.
not sure why they used off sizes for the hex fasteners. i think they used 1.5mm and 2.5mm. wtf.
brush arrangement:
aixun:
yihua:
as you look at the pics, take note of how the solder chamber is well isolated on the aixun. because of the gasket material, i don't think there's much chance of solder particles going where they're not supposed to.
main pcb:
amusingly, the motor pulley and brush bearing stuff is totally sealed inside a milled aluminum block. they use NSK ZZ bearings on the brushes. i'm generally impressed with all the metal parts in this build. well finished, chamfered, deburred. they use thread locker on the main fasteners.
the magnets for drawer latching are mounted to the aluminum motor/brush block:
i lol'd when i noticed that the drawer was actually made out of steel (to stick to the magnets). i guess they finished and painted it to pretty closely match the look of the aluminum body's anodization. steel drawer on left, main aluminum chassis on right:
here's a shot of the main body. one solid piece of aluminum. i guess they extruded that and then did follow up milling operations? i don't know much about DFM, but that doesn't look cheap at all to me. i'm surprised they went with this method of construction, but it looks sweet. maybe someone with more manufacturing experience can comment on this.
here's a closeup of the sensing flex pcb near the aperture. you can see they goobered it up with silicone, but not quite well enough for my taste. i put a dab of whiteout (correction fluid) over the exposed pins after i looked at this pic:
some before and after tip cleaning shots. normally, i would not run them this long in there, but i wanted to see how much crap it could scrape off:
« Last Edit: October 17, 2024, 01:35:25 am by digger »
The following users thanked this post: shabaz, thm_w, fkfaraz
Offline thm_w
  • Non-expert
Re: Aixun CM30 Automatic Tip Cleaner Teardown and Review
« Reply #1 on: October 17, 2024, 08:33:00 pm »
Build quality looks incredible, better than JBC. NSK bearing is just over the top, good china brand would have been fine.
In terms of the extruded aluminum enclosure, the bare extrusion itself is very cheap even in smaller quantities, hardly more than the cost of aluminum. The die that they pass the aluminum through is likely <$2k in china.
The machining part, its complex, maybe 4 or more operations to get all of those angles. Normally not cheap. In China though, CNC costs are unbelievably low right now.
« Last Edit: October 17, 2024, 08:36:03 pm by thm_w »
The following users thanked this post: shabaz, digger
Offline shabaz
« Reply #2 on: October 17, 2024, 10:39:05 pm »
Very useful review. Is it fast to spin up? The Aixun ads mention 'microsecond' level sensing, but was just curious how it felt in use. It seems straightforward to maintain/repair.
I'm tempted to buy two of them (one for a friend who is still using sponges) (incidentally there's an 'early bird' deal with quite a saving from 'SK Tech Store' on AliExpress, but Qty 1 allowed so I'll get someone else to order the other one). I've looked for the CM30 brushes, but cannot find a supplier. However, since a ball of steel wool lasts me a decade easily, I'm wondering if the CM30 brushes may last many years too. Worst case, it looks like the Quick 310 brushes might be approximately the same (or perhaps could be modified as a last resort).
« Reply #3 on: October 17, 2024, 10:53:24 pm »
the sensing is snappy.
if you're remotely handy, i think you should be able to get some other brushes working in there. i'm not worried about it personally. in fact, i bet i could get the spare yihua brushes to work in it, but i'm not sure if the OD (incl. bristles) is the same. i bet it would still be fine if it's not exactly the same, but it may feel a little different.
« Last Edit: October 17, 2024, 10:56:07 pm by digger »
Offline shabaz
« Reply #4 on: October 17, 2024, 11:01:01 pm »
Thanks. And agree, even if the brushes wore out, it's not rocket-science to adapt other brushes, especially at this low cost, that's not a showstopper.
« Reply #5 on: October 17, 2024, 11:04:04 pm »
hm... i'd say the engineering on the jbc looks more complicated with all the injection molded parts and stuff, but i prefer all-metal on the aixun. all other things being equal, i suppose i prefer the build quality of the aixun. but who knows about the actual longevity or how the UX is on a real jbc. i want to believe jbc has a lot of design refinements that add value, but then again maybe not. the jbc brushes look more elite.
https://www.stevenrhine.com/?p=132118
https://www.eevblog.com/forum/reviews/jbc-clmu-pa-senior-tip-cleaner/
« Last Edit: October 17, 2024, 11:12:23 pm by digger »
« Reply #6 on: October 17, 2024, 11:07:25 pm »
so the brush 'axis' is the two twisted wires common to most axial brush (and bottle cleaner) construction. it is terminated with a crimped collar. the collar has two flat sections 180° apart. the collar goes into the 'mount collar' (where those ZZ bearings are) and secured with two set screws.
that's pretty easy to adapt i think.
you can see it fairly clearly in this pic:
https://i.ibb.co/Nx4x9m2/PXL-20241010-022424131.jpg
Offline thm_w
  • Non-expert
« Reply #7 on: October 18, 2024, 09:47:20 pm »
Yeah the quality of the brushes is the one thing that looks better, but those brushes cost more than the entire Aixun unit at $120.
Injection molding takes more design time for sure, but the intent is only to produce a cheaper product, not a superior one, in this case.
The following users thanked this post: digger
