Author Topic: Aixun T3AS vs T3A  (Read 6498 times)
Offline CDN_HussarTopic starter
Aixun T3AS vs T3A
« on: June 01, 2023, 02:11:36 pm »
Besides the cheaper looking stand that is offered with the T3AS, what are the main differences between the new T3AS and the T3A?
Offline heygeorge
  • Country: sg
Re: Aixun T3AS vs T3A
« Reply #1 on: June 03, 2023, 08:09:06 am »
The main different first is friendly to the budget :-DD
Offline JHAnd
« Reply #2 on: June 17, 2023, 07:32:24 pm »
No place to put brass cleaner i the T3AS stand.
Seems T3AS does not allow for T12 handle only T245 handle.
I read somewhere that the T3AS has a ring transformer
Offline gabrieLL
  • Country: sk
« Reply #3 on: June 17, 2023, 07:47:53 pm »
T3AS has SMPS just like the old one. T410 and T420(D) have transformers.
https://www.aixuntech.com/product/t3as-allinone-200w-soldering-station-economical-welding-station-with-t245-handle/
T3AS All-in-One 200W Soldering Station Economical Welding Station with T245 Handle
Market Price: US$ 102/PC
• Applicable to T245 handle, meet requirements for soldering with high power
• Compatible with JBC tips, 100% matching with temp rising rate and temp control accuracy
• Soldering station and cradle all in one design, save space, easy for operation
200W digital switching power supply, providing efficient power for heating up, rapid heating in 2s
• Standby function, save energy and protect tips
Offline JHAnd
« Reply #4 on: June 18, 2023, 07:02:54 am »
Seems the Aixun site has contradictory information:
"200W high power ring transformer, providing efficient power for heating up, rapid heating in 2s"
Look here:
https://www.aixuntech.com/newsinfo/aixun-new-product-launch-t3as-allinone-200w-soldering-station/
Perhaps they changed their mind somwhere in the process of releasing it
Offline gabrieLL
  • Country: sk
« Reply #5 on: June 19, 2023, 11:45:45 am »
I am pretty sure that is a typo. Would a 200W toroidal transformer fit into the dimensions of T3A/B ?  Dimension 145*110*54mm
« Last Edit: June 19, 2023, 01:13:42 pm by gabrieLL »
Offline mastershake
« Reply #6 on: June 19, 2023, 05:36:56 pm »
i have them both here give me a few days ill open the s model and see whats inside
Offline gabrieLL
  • Country: sk
« Reply #7 on: June 19, 2023, 07:32:41 pm »
Thank you.
 I can't decide between the T3B vs T3BS. As far as I know the difference is only the handle holder/stand. The T3BS is cheaper due to the stand. There might be a newer PCB revision but other than that I do not expect a toroidal transformer in it.
Is the T3B stand worth the extra over the simpler T3BS ?
I am curious about the T3BS  holder. How they solved the dormancy.(GND through the body or is there a cable ?)
Offline mastershake
« Reply #8 on: June 20, 2023, 12:46:17 am »
yes there is a new pcb. the big difference is it has both the t3a and t3b on one board. then they wire or fill it to match. again i have not looked close enough yet to see the exact differences but thats what im told its similar to the new one that some of the t3a are getting when people order those the black pcb version. judging by the weight there is not a toroid in there unless its tiny lol and imo yes the t3b personally (again imo) is a way nicer setup then the s model i personally hate the mounted stand and i really like the default one from the 3a and 3b.
The following users thanked this post: gabrieLL
Offline JHAnd
« Reply #9 on: June 20, 2023, 04:44:04 am »
Thanks for the info!
I imagine it would be possible to take off the T3AS stand somehow if you really wanted and mod it with a cable, but then it would be less hassle to buy the T3A instead
Offline gabrieLL
  • Country: sk
« Reply #10 on: June 20, 2023, 02:02:22 pm »
Could you make a photo of the T3AS stand ? Is it permanently attached with a glue or screw ? Is the dormancy working without issues ?
Is the sponge really enough or do you prefer the brasswool ?
« Reply #11 on: June 29, 2023, 02:00:34 pm »
Just got mine yesterday.  Note the mounting screws.
« Last Edit: June 29, 2023, 02:14:26 pm by CDN_Hussar »
« Reply #12 on: July 25, 2023, 06:58:54 pm »
Just noticed the new operation video on YT...
Offline coppice
« Reply #13 on: August 15, 2023, 01:22:49 pm »
Look here:
Why do you jump to a conclusion about what ring means in this context. We generally use the terms toroidal transformer and resonant transformer, but we only say ring transformer for one powering a doorbell. So, which poor translation do you think matches this scenario best? I would guess a resonant SMPS.
Offline brainrape
  • Country: at
    • eevblog
« Reply #14 on: October 01, 2024, 11:36:08 am »
i got the t3as today with the old stand and the standby function is working
you have to remove the banana plug and attach a cable shoe
when you look at the station from behind the right socket switches the iron to standby
i will test if grounding problem still exists hopefully not
cheers
Offline ceut
« Reply #15 on: March 12, 2025, 07:44:20 pm »
cheers
Hello,
Sorry to dig up this topic, but I can't find any usefull information on the T3AS  :-\
It seems that there is only information for the T3A.
My question is : have you tested if the tip is grounded properly on this model ?
Thank you  :)
