Author Topic: Logitech nano receiver teardown (USB DONGLE)  (Read 33550 times)
Offline Psi
Re: Logitech nano receiver teardown
« Reply #1 on: December 25, 2011, 01:01:49 pm »
For reference/comparison, here's what the cheap Deal Extreme bluetooth receiver looks like
Dunno what the IC is, cant read it.
« Last Edit: December 25, 2011, 01:03:38 pm by Psi »
Online amyk
Re: Logitech nano receiver teardown (USB DONGLE)
« Reply #2 on: December 26, 2011, 11:22:48 am »
That is a Conwise CW6626M.
(See page 24 of the datasheet, the pinouts agree.)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: December 26, 2011, 02:12:27 pm »
is it that easy to build a USB + 2.4GHz trans ceiver?!
Offline lpc32
« Reply #4 on: January 08, 2015, 03:24:16 am »
Is that white component an antenna?
And can the firmware be read?
« Last Edit: January 08, 2015, 03:17:44 pm by lpc32 »
Offline Fraser
« Reply #5 on: January 08, 2015, 03:53:20 am »
White component = 2.4GHz SMD ceramic antenna. Very common in miniature Wi-Fi and Bluetooth modules and more predictable than PCB antennas on cheap FR4.
Aurora
Offline miguelvp
« Reply #6 on: January 08, 2015, 07:46:09 am »
I have a TrimSlice that came with a Bluetooth USB 2.0 Dongle, just plugged in in my system to see if Windows 7 recognized it and came up as CSR Bluetooth Chip. Device type: Bluetooth Radios, Manufacturer Realtek Semiconductor Corp.
Hardware ID: USB\VID_0A12&PID_0001&REV_0134
It looks the same as Psi but it's grey color, but I have not taking it apart. Internet searches for a Realtek Bluetooth USB 2.0 dongle shows them all with black plastic like Psi's.
Totally forgot about it until I saw the picture on this thread
I guess my desktop now has Bluetooth from now on :)
Offline janekm
« Reply #7 on: January 08, 2015, 08:27:04 am »
Aurora
Well I would argue that the usual reason for using a ceramic chip antenna is the smaller size that can be achieved (since the active element is folded in 3D space inside the ceramic, and a material with much higher dielectric constant compared to FR-4 can be chosen to further shorten the wavelength). The efficiency of a small ceramic chip antenna is considerably worse than a decent-sized (i.e. much larger) PCB antenna even without perfect control over the FR-4 dielectric constant.
That tiny one on this dongle won't work great at all but it's enough for a mouse sitting next to the dongle or at most a few meters away.
Offline lpc32
« Reply #8 on: January 08, 2015, 03:18:36 pm »
But it's not much of a size difference in the end. And it costs more. :)
Offline Fraser
« Reply #9 on: January 08, 2015, 04:22:06 pm »
I have never used ceramic antenna as I always tend to use conventional monopole or dipole antenna and do not mess with PCB antennas very much in my transmitter designs. I found a useful little PDF that details antenna types and requirements.
I attach it for your information. I was wrong about the ceramic antenna being better for poor dielectric FR4 applications. Apparently they need careful use with a good dielectric substrate and ground-plane !
The only advantage I can see in them in small size.
I do not see me designing using ceramic antennas any time soon.
Aurora
Offline lpc32
« Reply #10 on: January 09, 2015, 12:32:50 am »
Thanks.
Now, if only someone tried modifying the firmware there...
Offline Deckert
    • TechBench
« Reply #11 on: March 15, 2015, 07:30:20 pm »
Did a quick opening of my Logitech nano receiver as well. Seems mine is possibly older, because it uses two discreet chips:
NRF24L01 - Ultra low power 2.4GHz RF Transceiver IC
AT90USB162 - Atmel 8-bit micro
From their site:
Atmel 8-bit AVR RISC-based microcontroller combines 16KB ISP flash memory with read-while-write capabilities, 512B EEPROM, 512 bytes SRAM, 22 general purpose I/O lines, 32 general purpose working registers, two flexible timer/counters with compare modes and PWM, USART, programmable watchdog timer
http://www.atmel.com/devices/at90usb162.aspx
Oscillator and antenna:
Micro controller and 2.4GHz tranceiver chip:
Some image processing to help highlight the Atmel chip number:
« Last Edit: March 15, 2015, 07:40:13 pm by Deckert »
Online amyk
« Reply #12 on: March 16, 2015, 03:10:46 pm »
The datecodes are from 2008 and that version looks quite hackable.
Offline lpc32
« Reply #13 on: March 16, 2015, 05:18:54 pm »
I found out recently that Logitech's "Nano" receiver is not the same as their "Unifying" one. Nothing like artificial limitations.
