Hmmmm this is embarrassing....
I have received the Rocket Scream controller but haven't purchased an oven yet. I check them out every time I go to the shops !
I need to get organised !
I am just about to order the Rocket Stream controller was actually communicating with the guy in Malaysia last night. The only distraction at this stage is I have discovered the T962/A reflow unit and wading through all the intel on those as to if that might make more sense.
Seems like a number of Chinese designed and manufactured products there are some issues however the weigh up is there is some engineering involved with the toaster oven as well SSR etc but there needs so engineering as well if I went the T962/a route.
If you ever get yourself organised would be great to hear how you got on? Did you order his K Thermocouple too?
My problem is not so much getting organised but making a decision!
Goodluck with your journey...
