Author Topic: Any opinions on the Aixun T420D?  (Read 100963 times)
Offline digger
Re: Any opinions on the Aixun T420D?
« Reply #125 on: June 20, 2024, 06:44:51 am »
actually, i got the set with all three handles because it ended up being about a dollar cheaper, lol. by spending slightly more, a better coupon triggered. i guess i'll see how it goes.
still, if anyone knows the answers to my questions, i'd love to hear more.
Offline ryanscott6
« Reply #126 on: September 30, 2024, 03:05:12 am »
So my T420D just showed up after being on the slow boat for the last month.  So far so good!  I picked up a genuine JBC T245-A handle to go with this station.  I can confirm the wiring is the same but mechanically it doesn't fit in the T420D socket.  The JBC uses a 6-pin connection and the T420D uses a 7-pin.  To get it to fit you'll either need to move the plastic end piece over from the Aixun handle or drill out the top pin location in the JBC plastic bit.  After that, it works great.
The following users thanked this post: marck120
Offline Meter Deter
« Reply #127 on: September 30, 2024, 09:29:36 pm »
has anyone done a mod to add a Power switch to the front of base ??
im going to buying AIXUN T420D. but the power switch in the back is inconvenient.
if someone has done the mod. please post pictures.
Offline marck120
« Reply #128 on: October 15, 2024, 01:00:51 pm »
Hi, how come your T420D has 7 pins, in some videos I saw there are 6 pins.
Offline ryanscott6
« Reply #129 on: October 15, 2024, 08:55:47 pm »
Good question!  Will be interesting to see if others get a 7 or 6 pin socket.  Maybe I got a newer revision of it or maybe all they had at the factory was 7-pin sockets for awhile.   I ended up sending my T420D back since wouldn't turn on all the time when hitting the switch, and when it did turn it, it hummed like a mf'er.
Offline marck120
« Reply #130 on: October 15, 2024, 10:06:14 pm »
Since your T420D had 7 pins at this point there are two different versions, I really don't know, I've been researching for three months, I have to make a decision, I'm still undecided, I don't know if it's better to spend 50 -80 euros for a T12 station like a KSGER / Quicko STM32, AIFEN A8, YIHUA 948DB +-II, or a JBC 245 clone (with linear transformer and compatible with original JBC handles) for about 220 euros, Aixun T420, GVM H3, Jabe UD-1200, or get to 300 euros and get an original JBC station, JBC BT-2BWA 140w, or an I-CON NANO MK2 80w considering that it is less powerful but the tips are cheaper.
Offline digger
« Reply #131 on: October 17, 2024, 12:44:33 am »
according to the UI, mine was produced 2024-3-2
it's 6pin connectors on everything (all 4 ports). both ports on the cradles and both ports on the back of the main unit.
i tested, and T115 and T245 work in either cradle. genuine JBC T245 also works.
i did not disassemble anything and look inside the cradles to see if there were some kind of subtle differences implied upthread like different pcbs.
Offline marck120
« Reply #132 on: October 17, 2024, 02:39:33 am »
Thanks for the confirmation, I was actually interested in the Aixun T420 with the single mount, can I ask where you purchased yours ?
Offline digger
« Reply #133 on: October 17, 2024, 03:07:29 am »
i have T420D. iirc, "US set E" from this listing: https://www.aliexpress.us/item/3256806814522103.html
idk if you have experience with aliexpress, but you should search the full name of the product on there and look at the final price from several sellers. the price is different probably if you are logged in. i usually just go for the cheapest seller.
also, i would get T420D, not T420. i bet T420 won't even be much cheaper, and it's useful to have two handles for a lot of things. i've used them simultaneously before.
also, this could be worth considering instead if you really only want one handle:
https://www.eevblog.com/forum/reviews/aixun-t413-200w-smart-soldering-station-compatible-with-t245t225-handle/
« Last Edit: October 17, 2024, 03:11:14 am by digger »
Offline marck120
« Reply #134 on: October 17, 2024, 04:03:21 am »
@digger
Thanks for the advice, actually I have been buying on Aliexpress for a short time, I check the price and the reliability of the seller, number of followers, how long he has been registered, feedback, I also use three extensions on the browser, AliHelper - shopping assistant, Alitools Shopping Assistant and Up Assistant, they give me a rating with a score.
The T420 actually costs about 90 euros less, it depends on the shop, in Italy I found it for 215 euros, if I get to 300 euros I think it is better to focus on the basic JBC model like the JBC BT-2BWA
The problem with the Aixun T413 is that it is not compatible with the original JBC handles, I had contacted AiXun via the AiXun Tech page on Facebook and this is what they replied to me:
Aixun Technology
T413 is equipped with a self-designed temperature control algorithm and intelligent software, so the traditional handles of some brands are not able to adapt to our system to enjoy more user-friendly functions.
In addition, a user who has the T413 told me that the station did not recognize the original JBC tips, it was necessary to heat the tips first to make them recognized.
The following users thanked this post: digger
Offline indi1984
« Reply #135 on: November 02, 2024, 11:59:57 pm »
I ordred mine a few weeks ago and got in touch with Aixun about this issue.   They stated the 7 pin was an "upgraded and improved design".   I explained that it was inconvenient to customers, as most handles out there were 6 pin.   I actually got a spare left side base in yesterday.  Took it apart, and can confirm that the harness from the left base to the main unit, pin 7 is not connected to anything.  (pin 7 is a a red wire in that cable, and is actually cut short at the left base side. Kinda shoddy as they ddint even heat shrink over the cut end.). In theory you can probably de-pin the 7th pin on the handle stands and be good to go, but I just drilled a small hole in the oem JBC 245 handle to accomodate.    I have a feeling that Aixun switched to a 7 pin connector, as everything I find states that the 6 pin has been discontinued/obsoleted by the mfg. ( RPC1-12P-6S(72) from Hirose ).
The following users thanked this post: thm_w, marck120
Offline Meter Deter
« Reply #136 on: November 14, 2024, 11:08:32 pm »
what is a stable Version everyone is using? im on the latest as of today V1.27. i only have my station for 1 week.
Offline Electro Fan
« Reply #137 on: December 07, 2024, 08:02:40 pm »
Anyone have any way of knowing (or have any thoughts regarding) if a recently produced T420 (not a D) will work straight out of the box with a real JBC T245 handle?  Thanks
Offline indi1984
« Reply #138 on: December 07, 2024, 09:50:49 pm »
It probably will work if you do the modification to drill the 6th pin hole in the JBC connector.   One note.  While the genuine JBC handle works with my T420D (with said mod), most aftermarket cartridges have failed very fast.   I now only use geniune JBC cartridges, and have had no issues since.
Offline Tonlun
« Reply #139 on: January 27, 2025, 08:34:21 am »
Did you know how to wire the original nt115 handle to work with the aixun?
Offline kblue
« Reply #140 on: February 15, 2025, 08:40:13 am »
Does the unit have any "CE" markings? It's an odd question, i know but sometimes i'm unlucky with importing stuff into eu/germany because if it arrives at "customs" and i have one "special guy" handling the stuff, if he doesn't see the "CE" marking, i cant import it. Others don't care, but i just don't want to risk it running into this one guy at customs.
Best wishes!
Offline rigrunner
« Reply #141 on: February 17, 2025, 02:02:00 am »
My box arrived covered in tape, but these are the markings on the outer box.
You can decide if they are good enough to get past "that guy" at customs?
Internet of Things: A solution desperately trying to find its problem
Offline rigrunner
« Reply #142 on: February 17, 2025, 02:14:28 am »
Anyone using genuine JBC tips being asked confirm handpiece when swapping tips?
My T420D came with the usual three non genuine tips. When I swap any of these in a handpiece the display shows a message to touch the cradle with the tip. Touching the cradle makes it happy and the tip heats up.
I have obtained genuine C245-913, C245-914 and C245-966. When I swap these in a handpiece I get the above touch cradle message, but that doesn't seem to be enough. I am then prompted to indicate to the base which handpiece is in use. Maybe this is normal with the larger tips that I currently have, but this is a little unexpected considering that the base detects which handpiece is connected?
Edit: My unit has 7 pin connectors V1.27 firmware
« Last Edit: February 17, 2025, 02:16:47 am by rigrunner »
Offline Corte
« Reply #143 on: February 19, 2025, 10:31:14 am »
Yes mine does the same, I talked to customer support of aixun and they told me only t245 asks for confirmation. But it's weird it sometimes asks sometimes doesn't..  and I've around 50c shoot out when I change the temperature. I'm considering sending it back and maybe getting new t400 smart station but thst one doesn't support jbc tips etc so couldn't decide yet..
Offline rigrunner
« Reply #144 on: February 19, 2025, 05:19:41 pm »
I tried a C245-944 tip today and that seems to auto detect without hiccup. I need to get a few more smaller tips to make sure it is just the larger ones that have an issue.
The T420D is in a shootout with my ADS200. Whichever bugs me the least can stay.
Offline Corte
« Reply #145 on: February 19, 2025, 08:14:37 pm »
I don't know if it's a issue or not but as I said customer support was saying because t245 higher wattage handle, they need tconfirmation only on that handle. But as I said since it doesn't ask the confirmation all the time, I found it a bit weird and maybe it's a software bug or something they couldn't fix
Offline rigrunner
« Reply #146 on: February 20, 2025, 05:16:28 am »
I've sent an email to support. Maybe something will come of it if more people identify the problem?  :-//
Offline digger
« Reply #147 on: February 22, 2025, 12:34:02 pm »
+1 sometimes it asks me, sometimes it doesn't. touching the tip to the thing doesn't really bug me.
Offline rigrunner
« Reply #148 on: February 23, 2025, 03:28:02 am »
My T420D asked me to confirm the handle type today using the supplied Aixun C245-K200. I left the K200 cartridge in a handle last time I used it. When I powered it on cold the next day it prompted for handle confirmation.
Offline black6host
« Reply #149 on: February 23, 2025, 03:47:33 am »
I noticed that too the last time I used it.  And, I had just updated the firmware...  ???
