Author Topic: Aoyue 701 Desoldering Station.  (Read 1477 times)
Offline henasTopic starter
« on: April 26, 2019, 01:10:59 pm »
I have Aoyue 701 combination vacuum desoldering/solder station not an "A" version. I believe this is knock of the original Hakko 701.
Playing with heating elements I managed to short solder part of the circuit. Desolder gun still works fine. Unfortunately two Ics 14 pin and 6 pin have their marking physically removed. 6 pin IC appear to be driver for the triac and seem to be OK but the 14 pin is cooked. I suspect this is quad Op-Amp maybe TL074.
Someone might know what IC's were used on this Chinese knock off. I suspect the same as on the original Hakko 701.
I already ordered heating element controller from Ebay never less would be nice repair it too.
Offline d3m0
Re: Aoyue 701 Desoldering Station.
« Reply #1 on: March 06, 2024, 10:55:43 am »
Hi, I send you a PM. Dont know if its working
Thanks!
