Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
stepper motor or serve motor
Poll
I need to use a 6v DC motor to run continously. should I use a stepper motor or can I use a servo motor without encoder circuit, considering cost and performance. the load may be 10 to 100 grams
stepper
0 (0%)
servo
3 (100%)
Total Members Voted:
3
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: stepper motor or serve motor (Read 2476 times)
poornakumar
Newbie
on:
November 26, 2013, 05:14:32 am »
please help me find the right component!
Logged
Psi
Super Contributor
Country:
Re: stepper motor or serve motor
Reply #1 on:
November 26, 2013, 06:43:37 am »
Do you need to know the absolute or relative position of the motor? I assume you don't since you want continuous rotation.
You can get continuous rotation servos quite cheap. (hobbyking etc.)
You drive them with a typical RC servo signal but the signal sets the speed, in either direction, instead of the position like a normal servo.
(Technically they're not a servos because they have no feedback, but they're still sold as a servo)
Last Edit: November 26, 2013, 06:54:02 am by Psi
Logged
amyk
Super Contributor
Reply #2 on:
November 26, 2013, 10:21:45 am »
Just get a standard DC motor if you don't need positioning...
Logged
Psi
Super Contributor
Country:
Reply #3 on:
November 26, 2013, 10:34:31 am »
If he needs gearing then a continuous rotation servo is much simpler since it already has all that built in.
But if he wants it to be simple to drive a DC motor is easier than a servo which needs a mcu or something to generate the pulses.
Logged
GeoffS
Supporter
Country:
Reply #4 on:
November 26, 2013, 11:34:41 am »
Some context would help.
What will the motor be used for? What size load will it be handling?
Logged
hackertom
Newbie
Country:
Reply #5 on:
January 30, 2017, 10:58:00 am »
http://www.batterfly.com/
This site sells original Hakko stations or not?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
