The 951 is pretty good, but here are some things:
- 951 takes longer to get to initial temp
- harder to change tips, particularly when it's hot
- On the 951 I have to use a much larger tip for larger (more heat dissipative) items
- seems like I don't have any issues with thermal capacity on the JBC
Example on the thermal characteristics: soldering banana plugs and other large items required using a larger tip and a lot more heating time on the 951. With the JBC it's no problem at all. IIRC, I think Dave and Rob's videos show some of this.
On the JBC, I can use a smaller tip, it comes to temp from sleep in the time it takes to pick up the iron and move to position.
Also, I like the JBC tweezers... really nice for SMD work.
Don't get me wrong, I think the 951 is a nice unit, and it's a lot less expensive. But, if you have the choice get the JBC.
I have two 951s, as I found I often needed a little bigger tip to solder some component when assembling a board, so rather than remove a hot tip, put in a new tip and then wait, I had two irons running. With the JBC I don't have to do that. With the JBC one tip has been enough for soldering small and most large components on a board, and it's easy to change tips while it's hot.
Had I known 2 years ago what I know now, I would have just bought the JBC.
