Hours
Cooling: fan forced cooling
Humidity
Work: 85% RH, 40 ?, 24 Hours
Does not work: 85% RH, 65 ?, 24 Hours
Height
Work: 3000 m
Does not work: 15,266 m
Mechanical Specifications
Size: 339mm * Width 110.5mm * 148.5mm high
Weight: about 2.4kg
Color TFT LCD display, waveform display is more clear and stable;
Extensive trigger functions: edge, pulse, video, slope, alternate;
Unique digital filter and waveform recorder;
Pass / Fail function;
• 32 automatic measurements;
• 2 set of reference waveforms, 20 groups of common waveforms, 20 groups of settings within the store / recall; support waveform, set, CSV and bitmap files U disk external storage and recall;
Manual, tracking, automatic cursor measurement function;
Channel waveform and FFT waveforms at the same time split-screen display;
Analog channel waveform mesh screen brightness and brightness adjustable;
Pop-up menu display mode, the user operation more flexible, natural;
Rich interface display style: classic, modern, traditional, simple;
Multilingual interface display, the English online help system;
Standard interface: USB Host: Support U disk U disk storage and a system through software upgrades; USB Device: support for PictBridge direct printing and PC connection with the remote control; RS-232.
